The ideal introduction to fully-featured compact multifunctionals, this color laser A4 device boasts a small footprint and a host of smart scanning, printing and connectivity options to help you work more productively.
The great all-rounder
Offering features usually only found in larger devices, small businesses and home offices can choose the i-SENSYS MF724Cdw with confidence. This color A4 laser all-in-one offers Canon quality and reliability to give you stress-free printing, scanning and copying. Fast warm-up times, double-sided printing and scanning at 20ppm, plus a 50-sheet duplex document feeder, help you accomplish essential office and admin tasks with the minimum of fuss. -
Easily achieve great results
Getting the full potential from your MF724Cdw couldn't be easier thanks to its' 8.9cm front-mounted color touch screen that offers access to the device's powerful features. Maintaining consistent quality from your MF724Cdw is just as easy: Canon's All-in-One cartridge design replaces all key components in one operation, while giving you fewer items to order and manage. -
Built for mobile working life
The MF724Cdw gives you the same intuitive user experience across your laptop, tablet and smartphone - whether you're in the office or on the move. Full support for iOS, Android, Google Cloud Print and Wi-Fi give you complete freedom to work how and where you choose. The free Canon PRINT Business app (iOS/Android) makes all these options effortlessly accessible inside and outside the office. And if you're concerned about keeping sensitive documents confidential, the Secure Print Function lets you protect print jobs using a PIN code. -
Scan, share and print via the cloud
The MF724Cdw's fast, detailed scanning capabilities are seamlessly integrated with a range of cloud-based storage, sharing and printing options. So you and your colleagues can easily access digital documents any time, any place and on any device. As well as seamless scanning integration with your PC using the MF Scan Utility or your mobile device using the Canon PRINT Business app, you can scan direct to email addresses, network folders or USB keys direct from your MF724Cdw for maximum choice and flexibility. -
Smart network capabilities
Integration into IT networks is easily accomplished thanks to the MF724Cdw's support for PCL5c/6 and Adobe PostScript printer languages. A remote web-based user interface makes it easy for IT managers to monitor, manage, maintain and update the device without needing to make a site visit - a valuable time saver. Compatibility with Canon's e-Maintenance remote service management platform means the MF724Cdw will drop seamlessly into a Canon MPS or fleet environment. A range of energy-saving features helps to minimize your total cost of ownership and keep your business sustainable.
- Canon i-SENSYS MF724Cdw - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 750 - 2000 pages
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Original Size
- 128 x 139.7 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 125 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC
- Power
- AC 230 V (50/60Hz)
- 43 cm x 48.4 cm x 47.9 cm
- 31 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- 40000 pages
- 750 - 2000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PCL 5c, UFRII LT, PDF, TIFF
- First Print Out Time B/W
- 14.5 sec
- First Print Out Time Colour
- 14.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 128 x 139.7 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 148 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 215.9 x 355.6 mm, Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 50 sheets
- 125 sheets
- RADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 165 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 125 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Printing: up to 10 ipm (A4) - B/W duplex , Printing: up to 10 ipm (A4) - colour duplex , Copying: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour , Copying: up to 10 ipm (A4) - B/W duplex , Copying: up to 10 ipm (A4) - colour duplex , Scanning: up to 20 ipm - B/W , Scanning: up to 20 ipm - colour , Scanning: up to 10 ipm - B/W duplex , Scanning: up to 10 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- LDAP, Secure Print, IPsec, 802.1x, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon Print Service Plug-in for Android
- Voltage Required
- 1200 Watt
- Power Consumption Standby
- 23 Watt
- Power Consumption Sleep
- 1 Watt
- First Copy Out Time B/W
- 15.5 sec
- First Copy Out Time Colour
- 16.2 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages , 1 x toner cartridge (cyan) - up to 1400 pages , 1 x toner cartridge (magenta) - up to 1400 pages , 1 x toner cartridge (yellow) - up to 1400 pages
- ISO/IEC 19798
- ENERGY STAR Certified
- 43 cm
- 48.4 cm
- 47.9 cm
- 31 kg
- Sound Emission
- 67 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
