Canon MF633Cdw is a feature-packed color laser multifunctional, with touchscreen operation and productivity-boosting duplex printing. The ideal choice for small businesses seeking seamless integration and hassle-free upkeep.
- Canon i-SENSYS MF633Cdw - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 5"
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to FTP, scan to PC, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 45.1 cm x 46 cm x 40 cm
- 22 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- 30000 pages
- 250 - 2500 pages
- Display Diagonal Size
- 5"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 10.9 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm, 215.9 x 355.6 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 1 sheet
- 100 sheets
- Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , ADF - 50 sheets weight: 50 g/m² - 105 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 18 ppm (A4) , Copying: up to 18 ppm (A4) , Scanning: up to 27 ipm - B/W , Scanning: up to 13.5 ipm - colour , Scanning: up to 48 ipm - B/W duplex , Scanning: up to 28 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Secure Print, 802.1x, IP filtering, MAC address filtering, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5 or later, Windows 10, MS Windows Server 2016
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon Print Service Plug-in for Android, iW Management Console, Canon PRINT Business
- Voltage Required
- 850 Watt
- Power Consumption Standby
- 13.6 Watt
- Power Consumption Sleep
- 0.94 Watt
- Warm-Up Time
- 13 sec
- First Copy Out Time B/W
- 12 sec
- First Copy Out Time Colour
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1400 pages - Canon 045 Starter , 1 x toner cartridge (cyan) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (magenta) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (yellow) - up to 690 pages - Canon 045 Starter
- ISO 9296
- ENERGY STAR Certified
- 45.1 cm
- 46 cm
- 40 cm
- 22 kg
- Sound Emission
- 49 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
