Enjoy this versatile and efficient multifunction color laser printer, with a color touchscreen and mobile compatibility. The perfect partner for small businesses, seeking a high-performing, but compact solution.
Efficient connectivity
With options like Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless connection across various platforms. -
Advanced security
Equipped with robust security protocols including 802.1x, IP filtering, MAC address filtering, and Secure Print, the Canon i-SENSYS MF631Cn prioritizes your document's safety at every level of operation. -
High-quality copying
Features such as 2 on 1, 4 on 1, Frame Erase Copy, ID Card Copy, and Toner Save, combined with a first copy out time as fast as 12 seconds for B/W and 14 seconds for color, enhance productivity without compromising on quality. -
Intuitive display
A 5-inch color touchscreen display offers an intuitive interface for all your printing, copying, and scanning needs, making complex tasks simpler and more accessible. -
Versatile media handling
Supports a wide range of media sizes and types, including envelopes, glossy paper, heavy-weight paper, and labels, providing flexibility for all your document handling requirements.
- Canon i-SENSYS MF631Cn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 5"
- Original Type
- Sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to FTP, scan to PC, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 45.1 cm x 46 cm x 34.7 cm
- 19.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- 30000 pages
- 250 - 2500 pages
- Display Diagonal Size
- 5"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 10.9 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Original Type
- Sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm, 215.9 x 355.6 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 1 sheet
- 100 sheets
- Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 18 ppm (A4) , Copying: up to 18 ppm (A4)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Secure Print, 802.1x, IP filtering, MAC address filtering
- Operating System Support
- Linux, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5 or later, Windows 10, MS Windows Server 2016
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon Print Service Plug-in for Android, iW Management Console, Canon PRINT Business
- Voltage Required
- 850 Watt
- Power Consumption Standby
- 13.6 Watt
- Power Consumption Sleep
- 0.94 Watt
- Warm-Up Time
- 13 sec
- First Copy Out Time B/W
- 12 sec
- First Copy Out Time Colour
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1400 pages - Canon 045 Starter , 1 x toner cartridge (cyan) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (magenta) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (yellow) - up to 690 pages - Canon 045 Starter
- ISO 9296
- ENERGY STAR Certified
- 45.1 cm
- 46 cm
- 34.7 cm
- 19.5 kg
- Sound Emission
- 49 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
