Wi-Fi-equipped A4 multifunctional that’s compact and easy to operate. The complete solution for small and home offices. This compact Wi-Fi enabled A4 laser multifunctional offers high-quality print, scan and fax capabilities that are effortless to use via your PC, smartphone or tablet.
The productivity-boosting All-in-One
If you're a small business or individual user, the i-SENSYS MF628Cw A4 laser multifunctional offers a great way to get more done. Impress customers with full-color sales and marketing documents. Effortlessly scan, share and archive those bulky paper files. Copy and fax anytime you need. A small footprint and smart looks combine with 14 ppm color printing to create a fully-featured first multifunctional for your small or home office. -
Effortless to use and maintain
You'll be impressed how easily you can access the MF628Cw's clever features. Many of them are controlled via an intuitive front-mounted color 8.9 cm touch screen that's easily customised to suit the way you work. So you can access the full potential of your MF628Cw in just a few taps. Maintaining your device is just as easy. Consistent reliability and renewed quality are ensured every time you change your toner cartridges thanks to Canon's All-in-One design. -
Built for mobile: inside and outside the office
If you're like most of today's workforce, you move between devices and locations as your workload demands. The MF628Cw is built with you in mind, and provides the same seamless experience across your PC/laptop, tablet and smartphone. Not only can you connect from your Mac or PC via Wi-Fi when you're in the office, you can also connect your iOS or Android device when you're on the go thanks to AirPrint and Mopria support. Google Cloud Print ready to benefit from printing via the cloud. -
Capture, share, save and store
If you regularly need to scan documents to email, share via the cloud, or store digitally, the MF628Cw will make your life simpler. A 50-sheet document feeder makes easy work of scanning multiple items. You can manage scanning from your PC using the MF Scan utility, or from your mobile device using the free Canon PRINT Business app. Using these, you can upload your scans direct to online cloud services like Dropbox, and enjoy the freedom of retrieving documents no matter where you are. The MF628Cw ticks all the boxes for agile businesses that want help to keep productive on-the-go. -
Sustainable, manageable, integration-friendly
Although it's designed with small and home offices in mind, the MF628Cw offers a comprehensive set of networkable printing and scanning capabilities. And its low energy consumption in Sleep and Standby modes, and its power-saving Auto Shutdown feature, make it a sustainable, cost-conscious choice.
- Canon i-SENSYS MF628Cw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 14 ppm (mono) / up to 14 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 128 x 139.7 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 83 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 125 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC
- Power
- AC 230 V (50/60Hz)
- 43 cm x 48.4 cm x 42.9 cm
- 26 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- 30000 pages
- 1500 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- UFRII LT, TIFF
- First Print Out Time B/W
- 18 sec
- First Print Out Time Colour
- 18 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 512 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 281 station(s)
- Broadcast Transmission
- 310 stations
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax memory backup, fax activity reports
Document & Media Handling
- Min Original Size
- 128 x 139.7 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 83 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 215.9 x 355.6 mm, 83 x 127 mm, Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 1 sheet
- 125 sheets
- ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 150 sheets size: 83 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 83 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 125 sheets
- Speed Details
- Printing: up to 14 ppm (A4) - B/W , Printing: up to 14 ppm (A4) - colour , Copying: up to 14 ppm (A4) - B/W , Copying: up to 14 ppm (A4) - colour , Scanning: up to 14 ipm - B/W , Scanning: up to 14 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- IPsec, 802.1x, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10
- Software Included
- Drivers & Utilities, Presto! PageManager, Canon Print Service Plug-in for Android
- Voltage Required
- 900 Watt
- Power Consumption Standby
- 20 Watt
- Power Consumption Sleep
- 1 Watt
- First Copy Out Time B/W
- 19 sec
- First Copy Out Time Colour
- 19 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 800 pages , 1 x toner cartridge (cyan) - up to 800 pages , 1 x toner cartridge (magenta) - up to 800 pages , 1 x toner cartridge (yellow) - up to 800 pages
- ISO/IEC 19798
- ENERGY STAR Certified
- 43 cm
- 48.4 cm
- 42.9 cm
- 26 kg
- Sound Emission
- 48 dBA (idle) / 65.2 dBA (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
