Canon i-SENSYS MF525x Mono Laser Multifunction Printer
Quicklinx: DJPZWS00 Mfr#: 2223C011
13 in stock
£492.76 ex VAT
£591.31 inc VAT
The i-SENSYS MF520 series are black and white multi-function, high-volume printers. They are aimed at small businesses and teams in larger enterprises requiring high-quality, fast printing with mobile connectivity.
  • Save time with fast print speeds of up to 43ppm
  • Increase productivity with double sided, single pass scanning
  • High quality 1200 x 1200 dpi print resolution
  • Easy operation with large colour touch screen
  • Improved flexibility with varied media support; A4, A5, A6
  • Increase control with the Universal Login Manager
  • Enhanced security & accounting with uniFLOW
  • Easy mobile integration with QR code & NFC function
  • Improve quality & reliability with Canon Genuine all-in-one cartridges
  • Customise your workflow with the Application Library
Canon i-SENSYS MF525x - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 7500 pages
Max Copying Speed
Up to 43 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 43 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity
650 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), NFC
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host, iFAX
AC 230 V (50/60Hz)
49.4 cm x 46.4 cm x 45.2 cm
20 kg
Printer Fonts
PCL x 93 , PostScript x 136
Fax Type
Plain paper
Printing Technology
Laser - monochrome
150000 pages
2000 - 7500 pages
Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Up to 43 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Up to 43 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
6.2 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 512 pages
PC Faxing
Yes (send only)
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
281 station(s)
Telephone / Fax Switch
Broadcast Transmission
310 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax activity reports
Document & Media Handling
Min Original Size
105 x 128 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
52 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
650 sheets
100 sheets
250 sheets
DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 550 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 199 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 43 ppm (A4) - B/W , Printing: up to 65.2 ppm (A5) - B/W , Printing: up to 34.4 ipm (A4) - B/W duplex , Copying: up to 43 ppm (A4) - B/W , Copying: up to 34.4 ipm (A4) - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering
Operating System Support
Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.8.5 or later, MS Windows Server 2016
Software Included
Drivers & Utilities, iW Management Console, uniFLOW online, uniFLOW online Express, Universal Login Manager
AC 230 V (50/60Hz)
1380 Watt
Power Consumption Standby
17 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
14 sec
First Copy Out Time B/W
6.4 sec
Consumables Included
1 x Cartridge (black) - up to 10000 pages - Canon 041
49.4 cm
46.4 cm
45.2 cm
20 kg
Sound Emission
28 dB (idle) / 53 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: 300 - 500
