Highly productive and efficient, the MF446x also benefits from customizable controls, wireless connectivity and the extensive security and cost-saving measures of the Universal Login Manager (ULM).
This fast and efficient mono laser printer from Canon has been optimised for small to medium-sized businesses with a multifunctional design that allows you to print, copy and scan from one machine. Offering a compact and space-saving solution, it includes intelligent mobile connectivity and an application library for customisable control. For added security, it includes Secure PIN release and Universal Login Manager controls and has a user-friendly 12.7cm colour touchscreen.
Efficient connectivity
With a range of connectivity options including Gigabit Ethernet, USB 2.0, and Wi-Fi(n), alongside mobile printing capabilities through Apple AirPrint, Google Cloud Print, and Mopria Print Service, this device ensures seamless integration into any workflow. -
Advanced security
Equipped with comprehensive security protocols such as 802.1x, AES, and Secure Print, the Canon i-SENSYS MF446x safeguards sensitive information, making it a suitable choice for businesses concerned with document confidentiality. -
High-quality copying
Automatic duplexing, a variety of copying features like 2 on 1, 4 on 1, and ID Card Copy, combined with a maximum copying resolution of 600 x 600 DPI, ensure high-quality outputs for all copying needs. -
Intuitive display
A 12.7 cm color touchscreen display enhances user experience by providing easy navigation and quick access to all printer functions. -
Versatile media handling
Supports a wide range of media sizes and types, including envelopes, heavy-weight paper, and labels, with a maximum media size of up to Legal (216 x 356 mm), catering to diverse printing needs.
- Canon i-SENSYS MF446x - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 38 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 38 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
- Standard Media Capacity
- 350 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to SMB, scan to PC
- Power
- AC 230 V (50/60Hz)
- 45.3 cm x 46.4 cm x 39.2 cm
- 17.2 kg
- 2-year Limited Warranty
- Printer Fonts
- PCL x 93 , PostScript 3 x 136
- Laser - monochrome
- 80000 pages
- 750 - 4000 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Up to 38 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Up to 38 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 5.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Min Original Size
- 105 x 128 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 350 sheets
- 100 sheets
- 150 sheets
- DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 30.3 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ppm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, Wi-Fi Direct, SNMP 3
- Operating System Support
- Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019
- Software Included
- iW Management Console, uniFLOW online, uniFLOW online Express, Universal Login Manager
- Voltage Required
- 1370 Watt
- Power Consumption Standby
- 9.4 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 14 sec
- Consumables Included
- 1 x Cartridge (black) - up to 3100 pages ISO/IEC 19752 - Canon 057
- 45.3 cm
- 46.4 cm
- 39.2 cm
- 17.2 kg
- Sound Emission
- 53 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
Canon i-SENSYS 057 Toner Cartridge Black | In Stock | £84.42 |
Canon 3010C002 057H Black Toner Cartridge 10K Page | In Stock | £148.38 |
