Canon i-SENSYS MF429x Mono Laser Multifunction Printer
Quicklinx: DJPXWS00 Mfr#: 2222C018
14 in stock
£282.61 ex VAT
£339.13 inc VAT
The i-SENSYS MF420 series are multi-function printers offering SMEs speed, durability, and quality. Mobile connectivity maximises productivity.
  • Save time with fast print speeds of up to 38ppm
  • Increase productivity with double sided single pass scanning
  • High quality 1200 x 1200 dpi print resolution
  • Easy operation with large colour touch screen
  • Improved flexibility with varied media support; A4, A5,A6
  • Increase control with the Universal Login Manager (MF428x and MF429x)
  • Enhanced security & accounting with uniFLOW (MF428x and MF429x)
  • Improve quality & reliability with Canon Genuine all-in-one cartridges
  • Application Library allowing automation, added shortcuts and a customised interface
  • Secure PIN feature allowing employers and employees maximum control over print jobs
Canon i-SENSYS MF429x - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 38 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 38 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, Google Cloud Print ready, Mopria certified, scan to SMB, iFAX, barcode printing
AC 230 V (50/60Hz)
45.3 cm x 46.4 cm x 39.2 cm
16.9 kg
Printer Fonts
PCL x 93 , PostScript x 136
Fax Type
Plain paper
Printing Technology
Laser - monochrome
80000 pages
750 - 4000 pages
Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Up to 38 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Up to 38 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
5.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 512 pages
PC Faxing
Yes (send only)
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
281 station(s)
Telephone / Fax Switch
Broadcast Transmission
310 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, answering machine interface, remote reception, Dual Access, fax activity reports
Document & Media Handling
Min Original Size
105 x 128 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
52 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
350 sheets
100 sheets
150 sheets
ADF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 30.3 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ppm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering
Operating System Support
Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.8.5 or later, MS Windows Server 2016
Software Included
Drivers & Utilities, iW Management Console, uniFLOW online, uniFLOW online Express
AC 230 V (50/60Hz)
1300 Watt
Power Consumption Standby
10 Watt
Power Consumption Sleep
0.9 Watt
First Copy Out Time B/W
6.6 sec
Consumables Included
1 x Cartridge (black) - up to 3100 pages - Canon 052
45.3 cm
46.4 cm
39.2 cm
16.9 kg
Sound Emission
55 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: 150 - 300
