Canon i-SENSYS MF244dw A4 Mono Multifunction Laser Printer
Quicklinx: CTRRWS00 Mfr#: 1418C101
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Output Type: Monochrome
Technology: Laser
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Hurry, only 1 left in stock!
£186.75 ex VAT
£224.10 inc VAT
Professional 3-in-1 mono laser printer perfect for small workgroups, with fast, high-quality, double-sided printing and enhanced mobile and cloud capabilities, plus network integration features.
  • Remote monitoring
    Access printer information, change network settings, set up the address book and check toner levels - all from the remote user interface.
  • Sustainable performance
    The printer's eco reports make it easy to monitor and track usage, while auto off and reduced power consumption modes help keep your carbon footprint to a minimum.
Canon i-SENSYS MF244dw - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
500 - 2500 pages
Max Copying Speed
Up to 27 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 27 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, postcards
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to Cloud, scan to PC
AC 230 V (50/60Hz)
39 cm x 37.1 cm x 36 cm
12.1 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
15000 pages
500 - 2500 pages
Display
5 lines
AirPrint Enabled
Standard Memory
512 MB
Copying
Max Copying Speed
Up to 27 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Memory Sort
Printing
Max Printing Speed
Up to 27 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, UFRII LT
Automatic Duplexing
First Print Out Time B/W
6 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm), 76.2 x 210 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
100 sheets
Paper cassette - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 35 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m²
Speed Details
Printing: up to 27 ppm (A4) - B/W , Printing: up to 15 ipm (A4) - B/W duplex , Copying: up to 27 ppm (A4) - B/W , Scanning: up to 20 ipm - B/W (300 dpi) , Scanning: up to 15 ipm - colour (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering
Operating System Support
Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, Apple Mac OS X 10.6 or later, MS Windows Server 2012 R2, Windows 10
Software Included
Drivers & Utilities, Presto! PageManager
AC 230 V (50/60Hz)
1150 Watt
Power Consumption Standby
4.1 Watt
Power Consumption Sleep
1.3 Watt
First Copy Out Time B/W
9 sec
Consumables Included
1 x Cartridge (black) - up to 900 pages
ENERGY STAR Certified
39 cm
37.1 cm
36 cm
12.1 kg
Sound Emission
52 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
Functionality: Printer
Functionality: Scanner
Technology: Laser
Brand: Canon
Price Range Ex VAT: 150 - 300
