Enjoy this connected 4-in-1 mono laser printer, built to deliver everything, a small office needs: print, copy, scan and fax from PCs, smartphones and tablets.
An ideal office companion
If you run a small business or work from a home office, you'll appreciate the fast, reliable mono print quality, touchscreen display and print, copy, scan and fax. -
Monitor from a PC or mobile
Access printer information, change network settings, set up the address book and check toner levels - all from the remote user interface (RUI). -
Sustainability matters
The printer's eco reports make it easy to monitor and track usage, while auto off and reduced power consumption modes help keep your carbon footprint to a minimum.
- Canon i-SENSYS MF237w - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 500 - 2000 pages
- Max Copying Speed
- Up to 23 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 23 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, bond paper, heavy-weight paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to Cloud, scan to PC
- Power
- AC 230 V (50/60Hz)
- 39 cm x 37.1 cm x 36 cm
- 11.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Mnaufacturer Warranty
- 2 years
- Fax Type
- Plain paper
- Laser - monochrome
- 15000 pages
- 500 - 2000 pages
- Display
- 6 lines
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 23 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Memory Sort
Printing
- Up to 23 ppm
- Printer Drivers / Emulations
- UFRII LT
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 256 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 104 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 114 stations
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax memory backup, fax activity reports
Document & Media Handling
- Min Original Size
- 105 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm), 76.2 x 210 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Paper cassette - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 35 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m²
- Speed Details
- Printing: up to 23 ppm (A4) - B/W , Copying: up to 23 ppm (A4) - B/W , Scanning: up to 20 ipm - B/W (300 dpi) , Scanning: up to 15 ipm - colour (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, Apple Mac OS X 10.6 or later, MS Windows Server 2012 R2, Windows 10
- Software Included
- Drivers & Utilities, Presto! PageManager
- Voltage Required
- 1120 Watt
- Power Consumption Standby
- 5.1 Watt
- Power Consumption Sleep
- 1.2 Watt
- First Copy Out Time B/W
- 9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 900 pages
- ENERGY STAR Certified
- 39 cm
- 37.1 cm
- 36 cm
- 11.4 kg
- Sound Emission
- 51 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
Service and Support
- 2 years
