Your basket is empty
Canon i-SENSYS LBP7680CX Colour Laser Printer
Quicklinx: CDLSWS00 Mfr#: 5089B014
For high quality output the i-SENSYS LBP7680Cx has 9600 x 600 dpi print resolution that's enhanced with automatic image refinement for a perfect finish on every print. The printer comes with large memory as standard, giving it the capacity to cope with large, complex documents and graphics, as well as the demands of network printing.
The i-SENSYS LBP7680Cx integrates seamlessly into your business operations through its support for the industry-standard PCL5c/6 and Adobe PostScript printing. With built-in Gigabit Ethernet connection it can also handle demanding workloads, while ensuring optimum network performance.
The i-SENSYS LBP7680Cx is Canon's the laser printer to offer direct print from any USB storage media. It supports Tiff, JPEG, PDF and XPS files and with the clear display screen users will find it easy to choose the file they want and then print it fast.
Canon i-SENSYS LBP7680Cx - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
25.2 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - colour - A4 (210 x 297 mm)
Max Resolution (Colour)
9600 x 600 dpi
Image Enhancement Technology
Automatic Image Refinement
Automatic Duplexing
USB, Gigabit LAN, USB host
RAM Installed (Max)
768 MB
Language Simulation
PCL 5C, PostScript, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, transparencies, labels, plain paper, coated paper, heavy-weight paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
60000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
AC 230V
Linux, Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4.9 - 10.7.x
41.4 cm x 49.9 cm x 34.6 cm
Printer Type
Printer
Print Speed
Wired
9600 x 600 dpi
Automatic Duplexing
Language Simulation
Fonts Included
93 x scalable , 10 x bitmapped , 136 x PostScript
Media Handling
RAM
RAM Installed (Max)
768 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
125 sheets
Duty Cycle
60000 pages
Print server
IEEE 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 1400 pages - Canon 718 , 1 x toner cartridge (cyan) - up to 1200 pages - Canon 718 , 1 x toner cartridge (magenta) - up to 1200 pages - Canon 718 , 1 x toner cartridge (yellow) - up to 1200 pages - Canon 718
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
950 Watt
Power Consumption Stand by / Sleep
1 Watt
Software Included
Drivers & Utilities, Canon Multifunctional Embedded Application Platform (MEAP)
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
52 dB
Sound Emission (Quiet Mode)
24 dB
41.4 cm
49.9 cm
34.6 cm
25.2 kg
CDLS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
CDLS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
CDLS C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
CDLS C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
