Product
Canon i-SENSYS LBP7660Cdn Colour Laser Printer
Quicklinx: 89BHWS00 Mfr#: 5089B011
For high quality output the i-SENSYS LBP7660Cdn has 9600 x 600 dpi print resolution that's enhanced with automatic image refinement for a perfect finish on every print. The printer comes with 768 MB of memory as standard, giving it the capacity to cope with large, complex documents and graphics, as well as the demands of network printing.
The i-SENSYS LBP7660Cdn integrates seamlessly into your business operations through its support for the industry-standard PCL5c/6. With built-in Gigabit Ethernet connection, it can also handle demanding workloads to ensure optimum network performance.
The superior energy efficiency of the i-SENSYS LBP7660Cdn means you can cut costs - as well as your impact on the environment. ENERGY STAR compliant, it consumes only 1.0 watts of power in sleep mode and has a low Typical Energy Consumption (TEC) figure, to make it one of the most efficient in its class. With automatic double-sided printing built-in you can reduce paper usage, not only saving money but also being more considerate to the environment.
  • High-performance color laser
    Maximize productivity within busy workgroups with this stylish color laser printer. Compact enough to sit on the desktop, it gives users the convenience of a printer close-by that delivers professional quality prints quickly. Canon's quick first-print technologies also mean there's little waiting time for documents.
  • Professional print quality
  • Easy to use
    Even novice users will find this color laser printer simple to operate. The intuitive 5-line LCD display makes it easy to setup and navigate between the different settings on the device.
  • Versatile connections
  • Money-saving energy efficiency
  • Easy to manage
    With a cost-effective all-in-one color cartridge - containing toner, drum and cleaning units - the printer is virtually maintenance-free. The cartridge is easily replaced in seconds, leaving no mess.
Canon i-SENSYS LBP7660Cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
25.2 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - colour - A4 (210 x 297 mm)
Max Resolution (Colour)
9600 x 600 dpi
Image Enhancement Technology
Automatic Image Refinement
Automatic Duplexing
USB, Gigabit LAN
RAM Installed (Max)
768 MB
Language Simulation
PCL 5C, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, transparencies, labels, plain paper, coated paper, heavy-weight paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
60000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
AC 230V
Linux, Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4.9 - 10.7.x
41.4 cm x 49.9 cm x 34.6 cm
Printer Type
Printer
Print Speed
Wired
USB, Gigabit LAN
9600 x 600 dpi
Automatic Duplexing
Language Simulation
Fonts Included
45 x scalable , 10 x bitmapped
Media Handling
RAM
RAM Installed (Max)
768 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
125 sheets
Duty Cycle
60000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge ( black ) - up to 1400 pages - Canon 718 , 1 x toner cartridge ( cyan ) - up to 1200 pages - Canon 718 , 1 x toner cartridge ( magenta ) - up to 1200 pages - Canon 718 , 1 x toner cartridge ( yellow ) - up to 1200 pages - Canon 718
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
950 Watt
Power Consumption Stand by / Sleep
1 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
52 dB
Sound Emission (Quiet Mode)
24 dB
41.4 cm
49.9 cm
34.6 cm
25.2 kg
89BH C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
89BH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
89BH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.76
89BH C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.82
