Canon i-SENSYS LBP7110Cw Colour Laser Printer
Quicklinx: 8HP9WS00 Mfr#: 6293B014AA
The natural choice for small businesses who demand the finest quality in print. This compact A4 laser printer offers up to 14 ppm in both color and black and white. With built-in Wi-Fi, it's the ideal choice for small businesses who want consistent, high-quality results.
  • Produce consistently superb print
    Small offices and workgroups can produce professional-quality A4 color laser printouts. Featuring 1200 x 1200 dpi print resolution, the LBP7110Cw is ideal for creating high quality full-color sales and marketing assets or documents containing fine graphics and detailed text. With the LBP7110Cw, it's easy to deliver consistently impressive results without the cost of outsourcing important print jobs.
  • Compact, convenient design
    The LBP7110Cw's sleek, low profile form blends easily into business environments. A small footprint means this desktop printer fits where space is at a premium. With its contemporary design and quiet operation it can be placed in customer-facing environments.
  • Network and Wi-Fi enabled for easier sharing
    The LBP7110Cw is tailor made for personal use or for sharing its productive capabilities within small workgroups, thanks to its network interface. The Remote User Interface (RUI) lets users and administrators monitor and manage machine status from their browsers. The LBP7110Cw has built-in Wi-Fi, for effortless connection to a wireless network without intrusive and restrictive cabling.
  • Save time and achieve more productivity
    14 ppm output in both mono and color helps you complete important or time-sensitive tasks more quickly. Canon's Quick First-Print technology improves response time from sleep mode, so you won't waste valuable time waiting for your printer to warm up. A 150-sheet cassette minimizes replenishment times so your workflows stay fluid and productive.
  • Easy to manage and maintain
    The all-in-one cartridge system reduces maintenance and provides continuous high quality output. A higher yield black toner cartridge is available for even less downtime. Simply replace the cartridge - containing toner, drum and cleaning units - and the printer is virtually as good as new. Convenient front loading enables easy, quick and clean cartridge replacement.
  • The cost-effective, energy-efficient choice
    The LBP7110Cw uses only 0.9 watts in sleep mode. It is ENERGY STAR certified and has a market-leading TEC (Typical Energy Consumption) rating, which helps you comply with your environmental and sustainability objectives as well as cost reduction targets.
Canon i-SENSYS LBP7110Cw - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
Desktop
16.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
83 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 14 ppm - B/W - A4 (210 x 297 mm) , Up to 14 ppm - colour - A4 (210 x 297 mm)
Max Resolution (Colour)
1200 dpi
USB, LAN, Wi-Fi(n)
RAM Installed (Max)
64 MB
Language Simulation
Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, glossy film, cards, coated paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray
Monthly Duty Cycle (max)
30000 pages
Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Linux, Apple MacOS X 10.5.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
40.6 cm x 45.4 cm x 25.5 cm
Printer Type
Desktop
Printer
Print Speed
Wireless
USB, LAN, Wi-Fi(n)
1200 dpi
First Print Out Time B/W
18 sec
First Print Out Time Colour
18 sec
Language Simulation
Media Handling
RAM
RAM Installed (Max)
64 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
83 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
125 sheets
Duty Cycle
30000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (cyan) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (magenta) - up to 800 pages - Canon 731 Starter , 1 x toner cartridge (yellow) - up to 800 pages - Canon 731 Starter
Power supply - internal
Frequency Required
50/60 Hz
800 Watt
Power Consumption Stand by / Sleep
10 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
49 dBA
40.6 cm
45.4 cm
25.5 cm
16.6 kg
8HP9 Canon 731 Cyan Cartridge In Stock £50.01
8HP9 Canon 731 Yellow Cartridge In Stock £50.01
8HP9 Canon 731 Magenta Cartridge In Stock £50.01
8HP9 Canon 731 Standard Cap Black Cart In Stock £45.71
8HP9 Canon 731 High Cap Black Cartridge In Stock £55.24
