Maintain peak productivity with Canon's flagship mono laser printer. Canon's flagship mono A4 laser printer offers fast 40 ppm output. Network ready, MEAP-enabled and with a robust design, it integrates seamlessly into busy offices and workgroups.
The LBP6780x provides a rapid First Print Out time of just 8.6 seconds and a quick recovery from sleep mode so there is no long wait for your documents.
Equipped with a 500-sheet cassette and 100-sheet tray as standard, the LBP6780x can be configured for a total paper supply of 1600 sheets.
More versatile and easier to integrate
MEAP, the Java-based platform for developing applications, is built-in so the LBP6780x can be incorporated into solutions - such as uniFLOW, which simplifies print output management while reducing cost. -
Complete workgroup print solution
Offering a rapid 40 ppm, Canon's flagship mono laser device is ideal for busy corporate offices and workgroups that need a productive, high performance robust printer. -
Consistently superb results
Professional print quality is delivered every time. With a print resolution of up to 1200 x 1200 dpi, the printer has large capacity memory as standard to support complex, network printing. Built-in Gigabit Ethernet connectivity provides seamless network integration, making it easy to share printing resources and handle demanding workloads. -
Enhance your productivity
The LBP6780x provides a rapid First Print Out time of just 8.6 seconds and a quick recovery from sleep mode so there is no long wait for your documents. -
Extensive paper supply
Equipped with a 500-sheet cassette and 100-sheet tray as standard, the LBP6780x can be configured for a total paper supply of 1600 sheets. -
Easy to use
The 5-line LCD and time-saving feature for printing files from USB storage make this printer easy to work with. Canon's All-in-One cartridge - containing toner and all essential parts - can be replaced in seconds and an optional high yield toner cartridge prints over double the usual amount of pages, for continuous output. -
Automatic double-sided printing
For professional-looking documents, the LBP6780x automatically prints on both sides of a document - saving paper and cutting overheads. -
Keeping you protected
Secure your information with the same advanced features available on imageRUNNER ADVANCE multifunctional printers. These include IPSec and LAN IEEE 802.1x compliance. Optional secure mailbox printing makes sure no confidential material gets into the wrong hands. -
Energy-saving design
The LBP6780x reduces environmental impact with class leading Typical Energy Consumption (TEC), helping support your environmental and sustainability objectives as well as reducing running costs.
- Canon i-SENSYS LBP6780x - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 16.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- RAM Installed (Max)
- 768 MB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, Canon Ultra Fast Rendering (UFRII)
- Media Type
- Envelopes, transparencies, labels, plain paper, index cards, heavy-weight paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 500-sheet paper cassette, 100-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 100000 pages
- Networking
- Print server
- System Requirements
- Linux, Apple MacOS X 10.5.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 45.4 cm x 42.4 cm x 34.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- PostScript Support
- Included
- First Print Out Time B/W
- 8.6 sec
- Fonts Included
- 93 x PCL , 136 x PostScript 3
- Media Handling
RAM
- 768 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 76.2 x 127 mm
- Media Weight
- 60 g/m² - 199 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m²
- Max Media Capacity
- 1600 sheets
- Output Trays Capacity
- 300 sheets
Duty Cycle
- 100000 pages
- Networking
- Print server
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752 - Canon 724
- Mobile Printing
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1400 Watt
- Power Consumption Stand by
- 15 Watt
- Power Consumption Sleep
- 5.4 Watt
- Software Included
- Drivers & Utilities, Canon Multifunctional Embedded Application Platform (MEAP)
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 54.5 dBA
- 45.4 cm
- 42.4 cm
- 34.5 cm
- 16.6 kg
