Canon i-SENSYS LBP6780x Mono Laser printer
Quicklinx: B6LDWS00 Mfr#: 6469B010AC
  • Windows 8 (32/64 bits)
Maintain peak productivity with Canon's flagship mono laser printer. Canon's flagship mono A4 laser printer offers fast 40 ppm output. Network ready, MEAP-enabled and with a robust design, it integrates seamlessly into busy offices and workgroups.
The LBP6780x provides a rapid First Print Out time of just 8.6 seconds and a quick recovery from sleep mode so there is no long wait for your documents.
Equipped with a 500-sheet cassette and 100-sheet tray as standard, the LBP6780x can be configured for a total paper supply of 1600 sheets.
  • More versatile and easier to integrate
    MEAP, the Java-based platform for developing applications, is built-in so the LBP6780x can be incorporated into solutions - such as uniFLOW, which simplifies print output management while reducing cost.
  • Complete workgroup print solution
    Offering a rapid 40 ppm, Canon's flagship mono laser device is ideal for busy corporate offices and workgroups that need a productive, high performance robust printer.
  • Consistently superb results
    Professional print quality is delivered every time. With a print resolution of up to 1200 x 1200 dpi, the printer has large capacity memory as standard to support complex, network printing. Built-in Gigabit Ethernet connectivity provides seamless network integration, making it easy to share printing resources and handle demanding workloads.
  • Enhance your productivity
  • Extensive paper supply
  • Easy to use
    The 5-line LCD and time-saving feature for printing files from USB storage make this printer easy to work with. Canon's All-in-One cartridge - containing toner and all essential parts - can be replaced in seconds and an optional high yield toner cartridge prints over double the usual amount of pages, for continuous output.
  • Automatic double-sided printing
    For professional-looking documents, the LBP6780x automatically prints on both sides of a document - saving paper and cutting overheads.
  • Keeping you protected
    Secure your information with the same advanced features available on imageRUNNER ADVANCE multifunctional printers. These include IPSec and LAN IEEE 802.1x compliance. Optional secure mailbox printing makes sure no confidential material gets into the wrong hands.
  • Energy-saving design
    The LBP6780x reduces environmental impact with class leading Typical Energy Consumption (TEC), helping support your environmental and sustainability objectives as well as reducing running costs.
Canon i-SENSYS LBP6780x - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
16.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
RAM Installed (Max)
768 MB
Language Simulation
PCL 5E, PostScript 3, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, transparencies, labels, plain paper, index cards, heavy-weight paper
Total Media Capacity
600 sheets
Media Handling
500-sheet paper cassette, 100-sheet multipurpose tray
Monthly Duty Cycle (max)
100000 pages
Print server
Linux, Apple MacOS X 10.5.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
45.4 cm x 42.4 cm x 34.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Included
First Print Out Time B/W
8.6 sec
Language Simulation
Fonts Included
93 x PCL , 136 x PostScript 3
Media Handling
RAM
RAM Installed (Max)
768 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 76.2 x 127 mm
Media Weight
60 g/m² - 199 g/m²
600 sheets
Media Feeders
1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m²
Max Media Capacity
1600 sheets
Output Trays Capacity
300 sheets
Duty Cycle
100000 pages
Print server
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752 - Canon 724
Mobile Printing
Power supply - internal
Frequency Required
50/60 Hz
1400 Watt
Power Consumption Stand by
15 Watt
Power Consumption Sleep
5.4 Watt
Software Included
Drivers & Utilities, Canon Multifunctional Embedded Application Platform (MEAP)
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
54.5 dBA
45.4 cm
42.4 cm
34.5 cm
16.6 kg
