Canon i-SENSYS LBP663Cdw Colour Laser Printer
Quicklinx: FFHJWS00 Mfr#: 3103C017
Select:
The LBP663Cdw is an ultra-fast, highly accurate, single-function color laser printer with features designed to enhance workflow in small and medium offices.
Compact in size, this highly accurate printer is perfect for the small to medium-sized businesses. A single-function colour laser printer, it boasts several useful features to boost productivity including fast output of up to 27 single-sided A4 pages per minute. Automatic double-sided printing ensures paper costs are kept to a minimum, and the Secure PIN option adds another level of security. Connect your mobile device to the printer using the Canon PRINT business app.
  • Efficient connectivity
    With options like Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi, alongside mobile printing capabilities through Apple AirPrint, Google Cloud Print, and Mopria Print Service, this printer offers versatile connectivity solutions for any office environment.
  • High-quality printing
    Achieve professional-grade prints with a maximum resolution of 1200 x 1200 DPI for both black and white and color documents, ensuring crisp and clear output every time.
  • Robust media handling
    Catering to a wide range of media sizes from A4 to Legal, and types including envelopes, glossy paper, and labels, the Canon i-SENSYS LBP663Cdw is equipped to handle diverse printing needs. With a 300-sheet total media capacity, it efficiently manages large print jobs.
  • Secure and reliable
    Featuring Secure Print to protect confidential documents and a monthly duty cycle of up to 50,000 pages, this printer is designed for reliability and security in busy work environments.
  • Eco-friendly operation
    With a sound emission as low as 28 dB in idle mode and energy-efficient power consumption, this printer operates quietly and sustainably, minimizing its impact on the office environment.
Canon i-SENSYS LBP663Cdw - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
20.7 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 355.6 mm
Print Speed
Up to 27 ppm - B/W - A4 (210 x 297 mm) , Up to 24.5 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 27 ppm - colour - A4 (210 x 297 mm) , Up to 24.5 ipm - colour duplex - A4 (210 x 297 mm) , Up to 49 ppm - B/W - A5 (148 x 210 mm) , Up to 49 ppm - colour - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
Media Type
Envelopes, labels, plain paper, cards, recycled paper, thin paper, postcards, glossy paper, coloured paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
AC 230V
Linux, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.9.5 or later, Apple macOS 10.14 or later
43.7 cm x 46.9 cm x 31.3 cm
2-year Limited Warranty
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.7 sec
First Print Out Time Colour
8.6 sec
Language Simulation
Fonts Included
45 x PCL , 136 x PostScript
Media Handling
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 148 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 200 g/m²
300 sheets
Media Feeders
Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Multi-purpose tray: 1 - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Output tray: 1 - 150 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 4000 pages
Print server
Security Protocols & Features
Secure Print
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 1200 pages - Canon 055 Starter , 1 x toner cartridge (cyan) - up to 1200 pages - Canon 055 Starter , 1 x toner cartridge (magenta) - up to 1200 pages - Canon 055 Starter , 1 x toner cartridge (yellow) - up to 1200 pages - Canon 055 Starter
Power supply
AC 230V
Frequency Required
50/60 Hz
1380 Watt
Power Consumption Stand by
17 Watt
Power Consumption Sleep
0.6 Watt
Software Included
Drivers & Utilities
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
28 dB
Sound Emission (Operating)
48 dB
43.7 cm
46.9 cm
31.3 cm
20.7 kg
FFHJ Canon 055H High Yield Ink Cartridge - Yellow In Stock £150.49
FFHJ Canon 055H High Yield Ink Cartridge - Magenta In Stock £150.49
FFHJ Canon 055H High Yield Ink Cartridge - Cyan In Stock £150.49
FFHJ Canon 055H High Yield Ink Cartridge - Black In Stock £109.44
