Canon I-SENSYS LBP654Cx Colour Laser 27ppm Multifunction Printer
Quicklinx: DTHYWS00 Mfr#: 1476C012
Enjoy quick, easy access to the LBP654Cx's features, with the elegant touchscreen. The keyless display allows users to navigate through the on-board functions with a simple tap, helping to save time and improve efficiency. The clear layout and intuitive design gives users fast access to functions they frequently require with minimal training. For small businesses, being as productive as possible is critical. That's why Canon has overhauled the engine inside the LBP650 series, to deliver high print speeds. This rapid performance increases user efficiency without compromising on quality, and produces a reliable, impressive output every time.
Canon's advanced laser technology enhances prints, with captivating hues that grab attention. Despite the rapid print speeds, the LBP650 range doesn't compromise when it comes to quality, with arresting and vibrant colors that add impact to any document. So, whether it's for sales, marketing, or just internal purposes, the Canon LBP650 printers supercharge your communications. Keeping maintenance to a minimum, the LBP650 range features an auto toner seal removal system, making consumables easier to replace. In addition, the all-in-one cartridges keep the printer running for longer, while built-in consumable monitoring helps small businesses more efficiently plan their supplies purchasing.
  • Intuitive touchscreen
  • Faster print speeds
  • Color engineered to impress
  • Less upkeep, more uptime
Canon i-SENSYS LBP654Cx - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 27 ppm - B/W - A4 (210 x 297 mm) , Up to 21.9 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 27 ppm - colour - A4 (210 x 297 mm) , Up to 21.9 ppm - colour duplex - A4 (210 x 297 mm) , Up to 49 ppm - B/W - A5 (148 x 210 mm) , Up to 49 ppm - colour - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
Media Type
Envelopes, labels, plain paper, recycled paper, thin paper, postcards, glossy paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Windows 8, Apple iOS, Microsoft Windows Server 2012, Apple MacOS X 10.7.5 or later, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016
47.6 cm x 46.9 cm x 37.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
5 inch LCD touch screen
Wireless
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
8.3 sec
First Print Out Time Colour
8.6 sec
Language Simulation
Fonts Included
93 x PCL , 136 x PostScript
Colour Management Features
Mopria
Media Handling
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 148 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
52 g/m² - 200 g/m²
300 sheets
Media Feeders
Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Bypass tray: 1 - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Output tray: 1 - 150 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 4000 pages
Print server
Security Protocols & Features
Secure Print
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 1100 pages - Canon 046 Starter , 1 x toner cartridge (cyan) - up to 1200 pages - Canon 046 Starter , 1 x toner cartridge (magenta) - up to 1200 pages - Canon 046 Starter , 1 x toner cartridge (yellow) - up to 1200 pages - Canon 046 Starter
Power supply
Frequency Required
50/60 Hz
1400 Watt
Power Consumption Stand by
17.6 Watt
Power Consumption Sleep
0.6 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
28 dB
Sound Emission (Operating)
48 dB
47.6 cm
46.9 cm
37.9 cm
21 kg
