Canon i-SENSYS LBP613Cdw Colour Laser Printer
Quicklinx: D0XPWS00 Mfr#: 1477C021
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
17 in stock
£144.07 ex VAT
£172.88 inc VAT
Marketing description is not available.
  • Be more productive
    Ideal for maximizing productivity within busy workgroups, the stylish i-SENSYS is compact enough to sit on the desktop. Users have the convenience of a mono laser printer close-by that delivers professional quality documents quickly. There's no time lost waiting for documents either.
  • High quality laser printing
    Give your business documents extra impact with crisp, black text and clear, bold graphics. With a high print resolution the i-SENSYS ensures the highest quality finish for all of your work. With high capacity memory, the printer is equipped to meet the demands of network printing, as well as printing large, complex documents and graphics in fine detail.
  • Easy to use
    Simple to use, even for inexperienced users, the printer has an intuitive LCD display that makes it easy to setup and navigate between settings.
  • Seamless network integration
    i-SENSYS makes it quick and easy to share printing across the network. It has Gigabit Ethernet connectivity built-in, to handle demanding workloads quickly, without affecting network performance.
  • Save energy and cut costs
    Cut paper costs and reduce wastage with automatic double-sided printing. A range of energy-saving features also helps you reduce running expenses. i-SENSYS is Energy Star certified. With a low Typical Energy Consumption (TEC) it is one of the most efficient printers in its class.
  • Trouble-free maintenance
    For maximum uptime with minimum maintenance the printer has a cost-effective all-in-one cartridge - containing toner, drum and cleaning units. The cartridge is easily replaced in seconds, leaving no mess. Use an authentic Canon laser cartridge and you can be sure of continuous high quality output.
Canon i-SENSYS LBP613Cdw - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
15.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 11 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 11 ipm - colour duplex - A4 (210 x 297 mm) , Up to 32 ppm - B/W - A5 (148 x 210 mm) , Up to 32 ppm - colour - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
Media Type
Envelopes, labels, plain paper, recycled paper, thin paper, postcards, glossy paper
Total Media Capacity
150 sheets
Media Handling
150-sheet paper cassette, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2500 pages
Print server
AC 230V
Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Windows 8, Apple iOS, Microsoft Windows Server 2012, Apple MacOS X 10.7.5 or later, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016
43 cm x 41.8 cm x 27.4 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
10.9 sec
First Print Out Time Colour
12 sec
Language Simulation
Fonts Included
45 x PCL , 136 x PostScript
Colour Management Features
Mopria
Media Handling
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
52 g/m² - 200 g/m²
150 sheets
Media Feeders
Paper cassette: 1 - 150 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Bypass tray: 1 - 1 sheet - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Output tray: 1 - 100 sheets
Output Trays Capacity
100 sheets
Duty Cycle
30000 pages
250 - 2500 pages
Print server
Security Protocols & Features
Secure Print
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 1400 pages - Canon 045 Starter , 1 x toner cartridge (cyan) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (magenta) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (yellow) - up to 690 pages - Canon 045 Starter
Power supply
AC 230V
Frequency Required
50/60 Hz
850 Watt
Power Consumption Stand by
10.8 Watt
Power Consumption Sleep
0.9 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
49 dB
43 cm
41.8 cm
27.4 cm
15.5 kg
Type: Printer
Wireless Capability: Wireless
Brand: Canon
Price Range Ex VAT: 100 - 150
