Be more productive
Ideal for maximizing productivity within busy workgroups, the stylish i-SENSYS is compact enough to sit on the desktop. Users have the convenience of a mono laser printer close-by that delivers professional quality documents quickly. There's no time lost waiting for documents either. -
High quality laser printing
Give your business documents extra impact with crisp, black text and clear, bold graphics. With a high print resolution the i-SENSYS ensures the highest quality finish for all of your work. With high capacity memory, the printer is equipped to meet the demands of network printing, as well as printing large, complex documents and graphics in fine detail. -
Easy to use
Simple to use, even for inexperienced users, the printer has an intuitive LCD display that makes it easy to setup and navigate between settings. -
Seamless network integration
i-SENSYS makes it quick and easy to share printing across the network. It has Gigabit Ethernet connectivity built-in, to handle demanding workloads quickly, without affecting network performance. -
Save energy and cut costs
Cut paper costs and reduce wastage with automatic double-sided printing. A range of energy-saving features also helps you reduce running expenses. i-SENSYS is Energy Star certified. With a low Typical Energy Consumption (TEC) it is one of the most efficient printers in its class. -
Trouble-free maintenance
For maximum uptime with minimum maintenance the printer has a cost-effective all-in-one cartridge - containing toner, drum and cleaning units. The cartridge is easily replaced in seconds, leaving no mess. Use an authentic Canon laser cartridge and you can be sure of continuous high quality output.
- Canon i-SENSYS LBP613Cdw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 15.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 11 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 11 ipm - colour duplex - A4 (210 x 297 mm) , Up to 32 ppm - B/W - A5 (148 x 210 mm) , Up to 32 ppm - colour - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
- Media Type
- Envelopes, labels, plain paper, recycled paper, thin paper, postcards, glossy paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet paper cassette, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Networking
- Print server
- Power
- AC 230V
- System Requirements
- Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Windows 8, Apple iOS, Microsoft Windows Server 2012, Apple MacOS X 10.7.5 or later, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016
- 43 cm x 41.8 cm x 27.4 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- First Print Out Time B/W
- 10.9 sec
- First Print Out Time Colour
- 12 sec
- Fonts Included
- 45 x PCL , 136 x PostScript
- Colour Management Features
- Mopria
- Media Handling
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 52 g/m² - 200 g/m²
- 150 sheets
- Media Feeders
- Paper cassette: 1 - 150 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Bypass tray: 1 - 1 sheet - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Output tray: 1 - 100 sheets
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 30000 pages
- 250 - 2500 pages
- Networking
- Print server
- Secure Print
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 1400 pages - Canon 045 Starter , 1 x toner cartridge (cyan) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (magenta) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (yellow) - up to 690 pages - Canon 045 Starter
- Power Device
- Power supply
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 850 Watt
- Power Consumption Stand by
- 10.8 Watt
- Power Consumption Sleep
- 0.9 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 49 dB
- 43 cm
- 41.8 cm
- 27.4 cm
- 15.5 kg
