Product
Canon i-SENSYS LBP253x Mono Laser Printer
Quicklinx: CDLPWS00 Mfr#: 0281C018
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Laser
£218.18 ex VAT
£261.81 inc VAT
Fully-featured, intuitive and compact A4 B&W laser printer designed for small corporate workgroups. This fast, compact A4 B&W laser printer stands out for its quality, simplicity and value-for-money. It features a color touch screen, NFC and a host of flexible connectivity options.
  • The perfect introduction to workgroup printing
    Small teams will find it quick and easy to print high quality documents with this impressively equipped A4 B&W laser printer. The i-SENSYS LBP253x's compact size and smart looks are ideal in customer-facing or busy working environments. And you'll complete everyday tasks faster with rapid 33 ppm output and the ability to start printing from idle or standby in just a few seconds.
  • Intuitive to operate
    You'll achieve great results straight out of the box thanks to the LBP253x's intuitive 8.9 cm touch screen. It puts the printer's smart, time saving features just a tap or two away: so even inexperienced users can access the LBP253x's full potential with ease. Consistent reliability and renewed quality are ensured every time you change your toner thanks to Canon's easy-to-replace All-in-one cartridge design - also available in a longer-lasting high yield version.
  • Great support for mobile and cloud
    Today's workers enjoy the flexibility of moving seamlessly between locations and devices. But no matter how or where you choose to work, your LBP253x is always ready and accessible. Print from your iPhone or iPad via Apple AirPrint, or your Android/Google device thanks to Mopria compatibility.
  • Connect and print with ease
    For extra simplicity and flexibility, why not use the LBP253x's Touch & Print NFC connectivity? Pair any compatible mobile device then print directly using the Canon PRINT Business app: it's as easy as that. Alternatively, choose the LBP253x's PC-less printing option that lets you print and preview PDF, JPEG or TIFF files direct from a USB Flash key. With thoughtful features like these, you'll find the LBP253x accommodates every print scenario hassle-free, keeping your business running smoothly.
  • Protecting your information and your bottom line
    Enjoy peace of mind using the Secure Print function that enables you to securely print private and confidential documents from your PC, tablet or smartphone using a PIN code. The LBP253x protects your profitability too, with features like double-sided printing that reduce wasted paper, and Auto Shutdown that conserves electricity when your printer's not in use.
  • Network and integration-ready
    The LBP253x offers sophisticated networking capabilities that fit seamlessly into larger corporate environments. Support for PCL5e/6 and Adobe PostScript makes this an ideal choice for managed environments; while the Remote User Interface saves valuable time because IT Managers can monitor and update settings without making a site visit. Support for Canon's uniFLOW output management platform will be welcomed by managed print service and Canon fleet operators, making this a great value all-round performer.
Canon i-SENSYS LBP253x - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
12.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 33 ppm - B/W - A4 (210 x 297 mm) , Up to 16.8 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
525 MHz
Language Simulation
PCL 5E, PostScript, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, labels, plain paper, index cards, heavy-weight paper, recycled paper, postcards
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 3000 pages
Print server
AC 230V
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
40.3 cm x 37.7 cm x 31.7 cm
Printer Type
Printer
Print Speed
Built-in Devices
LCD touch screen
Wireless
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6 sec
Language Simulation
Fonts Included
93 x PCL , 136 x PostScript
Media Handling
525 MHz
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 3000 pages
Print server
Security Protocols & Features
Secure Print, Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2100 pages - Canon 719
ISO/IEC 19752, ISO 9296
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1150 Watt
Power Consumption Stand by
12.1 Watt
Power Consumption Sleep
1 Watt
Software Included
Drivers & Utilities
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
53 dB
40.3 cm
37.7 cm
31.7 cm
12.4 kg
CDLP C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
CDLP C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
CDLP C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.76
CDLP C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.82
Type: Printer
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: 33ppm
Brand: Canon
Price Range Ex VAT: 150 - 300
