Canon I-SENSYS LBP236DW Mono Duplex Printer
Quicklinx: GV4BWS00 Mfr#: 5162C013
Select:
Fast, reliable black and white single-function laser printers with enhanced mobile connectivity.
Transform your black and white printing with advanced productivity
Mono single-function laser printers in the Canon i-SENSYS LBP230 Series are designed to keep you securely connected, with speed, reliability, and mobile connectivity for efficient and productive printing.
Boost workflow efficiency
33-38ppm A4 black and white print speeds in the Canon i-SENSYS LBP230 Series deliver maximum productivity, with double-sided printing as standard.
Protect documents and devices
Robust and reliable security protects sensitive documents as well as your network, while Secure PIN functionality* prevents sensitive documents being automatically released.
Stay connected wherever you are
Mobile connectivity means you can conveniently print from wherever you are – either through the Canon PRINT Business app, AirPrint (iOS) or Mopria (Android).
  • Boost workflow efficiency
  • Protect documents and devices
    Secure PIN functionality prevents sensitive documents being automatically released.
  • Stay connected wherever you are
    Mobile connectivity means you can conveniently print from wherever you are - either through the Canon PRINT Business app, AirPrint (iOS) or Mopria (Android).
Canon i-SENSYS LBP236dw - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
9.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 63.1 ppm - B/W - A5 (148 x 210 mm) , Up to 31.9 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
800 MHz
RAM Installed (Max)
1 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, labels, plain paper, recycled paper, thin paper, label paper, postcards, coloured paper, heavy paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
AC 220-240 V
Linux, Windows 8.1, Windows 10, Apple MacOS X 10.11 or later, Microsoft Windows Server 2022, Windows 11
40.1 cm x 37.3 cm x 25 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Numeric key pad, 5 line LCD display
Wireless
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
5.5 sec
Language Simulation
Fonts Included
45 x PCL , 136 x PostScript 3
Media Handling
800 MHz
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
350 sheets
Media Feeders
Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Multi-purpose tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
750 - 4000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 3, HTTPS, IPPS, IPv4, IPv6
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Access Point Mode
TLS v1.3
Power supply
AC 220-240 V
Frequency Required
50/60 Hz
1330 Watt
Power Consumption Stand by
9 Watt
Power Consumption Sleep
0.9 Watt
Software Included
Drivers & Utilities
10 °C
30 °C
20 - 80% RH (non-condensing)
Sound Emission (Operating)
54 dB
40.1 cm
37.3 cm
25 cm
9.5 kg
GV4B Canon i-SENSYS 057 Toner Cartridge Black In Stock £80.06
GV4B Canon 3010C002 057H Black Toner Cartridge 10K Page In Stock £150.94
