Canon i-SENSYS LBP151DW Mono Laser Printer
Quicklinx: CDLNWS00 Mfr#: 0568C009
The i-SENSYS LBP151dw is a fast, compact, PCL-ready, Wi-Fi and mobile-enabled black and white laser printer that's affordably priced and ideal for a wide range of uses.
  • Speed, space and savings
    The i-SENSYS LBP151dw delivers outstanding speed from a space-saving device, at a very affordable price point. A brisk print speed of 27 ppm is complemented by double-sided printing, a first page out time (FPOT) of 8 seconds and Canon's Quick First-Print technologies, to ensure speedy printouts, even from sleep mode.
  • Wi-Fi, network and mobile-ready
    Connecting the printer to an Ethernet or Wi-Fi network is as easy as pushing a button. You can print wirelessly from any Mopria-enabled mobile device, using the free plugin. And you can access a wide range of advanced features on your iOS or Android device with the free-of-charge Canon PRINT Business app.
  • Google cloud print-ready
    The i-SENSYS LBP151dw will connect directly to the cloud without a PC. You can connect it to your Google Cloud Print account in seconds, and immediately start printing to it from any enabled device.
  • PCL-ready
    For IT professionals, the i-SENSYS LBP151dw is the perfect solution to numerous problems, attaching seamlessly to the network and providing compact, inexpensive reliability.
  • Efficient, low power consumption
    This printer is both quiet, making it ideal for retail environments, bank branches and hotel receptions and has class-leading energy efficient with low power consumption.
Canon i-SENSYS LBP151dw - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
8.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 27 ppm - B/W - A4 (210 x 297 mm) , Up to 15 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
400 MHz
RAM Installed (Max)
512 MB
Language Simulation
PCL 5E, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, recycled paper
Total Media Capacity
250 sheets
Media Handling
250-sheet paper cassette, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
500 - 2000 pages
Print server
AC 230V
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
39 cm x 36.5 cm x 24.5 cm
Printer Type
Printer
Print Speed
Wireless
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
8 sec
Language Simulation
Fonts Included
45 x PCL
Media Handling
400 MHz
RAM
RAM Installed (Max)
512 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
15000 pages
500 - 2000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1700 pages - Canon 737 Starter
ISO/IEC 19752, ISO 9296
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1120 Watt
Power Consumption Stand by
2.6 Watt
Power Consumption Sleep
1.1 Watt
Software Included
Drivers & Utilities, Canon Print Service plug-in for Android, Canon PRINT Business
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
52 dB
39 cm
36.5 cm
24.5 cm
8.6 kg
CDLN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
CDLN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.56
CDLN C2G 2m Cat6a Shielded Patch - Blue In Stock £7.11
