Canon i-SENSYS FAX-L410 Mono Laser Multifunction Printer
Quicklinx: B24VWS00 Mfr#: 6356B010AA
Type: Copier / fax / printer
Functionality: Copier, Fax, Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
£431.09 ex VAT
£517.30 inc VAT
Industry-fastest, laser fax machine with duplex ADF is ideal for robust, everyday use. This robust, compact Super G3 laser fax machine, with its large LCD display, fast performance and automatic duplex ADF, is ideal for everyday use within any business.
The i-SENSYS FAX-L410 simplifies usability with its intuitive, large LCD display. Faxing is quicker through the 39 one-touch and 200 coded speed dials, which stores regularly used numbers so they do not need to be redialed every time. The 250-sheet paper capacity minimizes the time spent refilling the cassette.
  • Fast faxing
    This high speed laser fax, printer and copier have a robust design that makes it perfect to deal with the everyday demands of a busy office. Productivity is boosted as there's little time spent by the fax machine waiting for documents. Several faxes can be received quickly without blocking the line, saving even more time, with speedy transmission also significantly reducing phone costs.
  • More productive, trouble-free faxing
    There's no worrying about whether your fax will be received, should paper or toner run out when you're away from the office, as the i-SENSYS FAX-L410 will store faxes in its large memory. For added convenience you can scan faxes into memory to send later. Dual Access means this can even be done at the same time as incoming faxes are being received.
  • Increased efficiency
  • Use less paper and reduce wasted time
    Automatic double-sided printing saves money by reducing paper usage. The Duplex Automatic Document Feeder (DADF) also makes it easier to copy and fax two sided documents as they can be scanned in one operation.
  • Fast laser printing
    Use the i-SENSYS FAX-L410, with its rapid copy and laser print speed of 25 ppm, as an additional laser printer for your workgroup. There's no waiting around for prints, copies or receiving faxes either, as Quick First-Print from sleep mode means there's no warm up time from standby.
  • Highly energy efficient
    Save energy and cost through the i-SENSYS FAX-L410's sustainable features. It is Energy Star qualified and consumes only 1.4 watts in sleep mode. The all-in-one cartridges - which combine the toner, drum and cleaning units to reduce maintenance requirement and increase reliability - minimize consumables and are easily recyclable.
Canon i-SENSYS FAX-L410 - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 impressions
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Original Size
127 x 140 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0
Office Machine Features
Ultra High Quality (UHQ) image processing
AC 230 V (50/60Hz)
47.2 cm x 44.5 cm x 35.8 cm
13.9 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 impressions
Display
5 lines
USB 2.0
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 25 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
Toner Save
Printing
Max Printing Speed
Up to 25 ppm
Printer Drivers / Emulations
UFRII LT
Automatic Duplexing
First Print Out Time B/W
5.8 sec
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Total Memory Capacity
Up to 512 pages
Fax Printing Speed
Up to 25 ppm
Fax Printing Resolution
1200 x 600 dpi
Handset
Corded handset
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
39 station(s)
Speed Dialing
200 station(s)
Telephone / Fax Switch
Broadcast Transmission
249 stations
Delayed Transmission
250 stations
Automatic redialing, remote reception, Dual Access
Document & Media Handling
Min Original Size
127 x 140 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 148 mm
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm), 76.2 x 148 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
100 sheets
Paper cassette - 250 sheets size: 76.2 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 50 sheets size: 127 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 25 ppm - B/W , Copying: up to 25 ppm - B/W
1 x USB 2.0
Operating System Support
MS Windows XP, Linux, MS Windows 7, MS Windows Vista, Apple MacOS X 10.4.9 or later
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
1320 Watt
Power Consumption Standby
4.5 Watt
Power Consumption Sleep
1.4 Watt
Warm-Up Time
13.5 sec
First Copy Out Time B/W
9 sec
Phone cable
Consumables Included
1 x Cartridge (black) - up to 1000 pages - Canon 728 Starter
ENERGY STAR Certified
47.2 cm
44.5 cm
35.8 cm
13.9 kg
Sound Emission
50 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
Functionality: Fax
Functionality: Printer
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: 300 - 500
