Your basket is empty
Canon i-SENSYS FAX-L170 Mono Laser Multifunction Printer
Quicklinx: 89BLWS00 Mfr#: 5258B028AA
This compact Super G3 fax is effortless to use and maintain. Offering superb energy efficiency with a range of professional fax features it's the ideal solution for small and medium-sized businesses.
Canon i-SENSYS FAX-L170 - multifunction printer (B/W)
Copier / fax / printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Max Copying Speed
Up to 11.8 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Original Size
127 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0
Office Machine Features
Ultra High Quality (UHQ) image processing
AC 230 V (50/60Hz)
37.2 cm x 30.3 cm x 30.3 cm
8.8 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 impressions
Display
5 lines
PC Connection
USB 2.0
Standard Memory
64 MB
Copying
Max Copying Speed
Up to 11.8 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
200%
Max Document Reduction
50%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save
Printing
Max Printing Speed
Up to 18 ppm
Printer Drivers / Emulations
UFRII LT
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Max Battery Backup Time
5 minutes
Total Memory Capacity
Up to 512 pages
Fax Printing Speed
Up to 18 ppm
Fax Printing Resolution
1200 x 600 dpi
Handset
Corded handset
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
30 station(s)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
140 stations
Delayed Transmission
140 stations
Automatic redialing, remote reception, Dual Access, auto reduction
Document & Media Handling
Min Original Size
127 x 139.7 mm
Max Original Size
Original Type
Sheets
30 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
150 sheets
100 sheets
Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 30 sheets size: 127 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 18 ppm - B/W , Copying: up to 11.8 ppm - B/W
1 x USB 2.0
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.4.9 - 10.7.x
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
1.02 kW
Power Consumption Standby
10 Watt
Power Consumption Sleep
1.5 Watt
Warm-Up Time
14 sec
First Copy Out Time B/W
22.3 sec
Consumables Included
1 x Cartridge (black) - up to 1000 pages - Canon 728 Starter
ENERGY STAR Certified
37.2 cm
30.3 cm
30.3 cm
8.8 kg
Sound Emission
53 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
