Canon i-SENSYS FAX-L150 Mono Laser Multifunction Printer
Quicklinx: 89BKWS00 Mfr#: 5258B020
i-SENSYS FAX-L150 has a cost-effective all-in-one cartridge, which contains toner, drum and all essential parts. Simply replace the cartridge in seconds - there's no mess or hassle. Use an authentic Canon cartridge and you can be sure of continuous high quality output.
  • Fast, cost-effective faxing
    Cut your communication costs down to a minimum with this super G3 fax, which transmits documents in as little as 3 seconds per page. As faxes can be sent and received in the shortest time possible, the telephone line is freed up.
  • Greater efficiency
    A 512-page memory safely stores all incoming documents so you can print out faxes later if paper or toner run out. Lengthy documents can also be scanned into the memory to be sent automatically, cutting transmission time and fax costs.
  • Quick, simple operation
    Dialing couldn't be simpler, even for inexperienced users, with all your regular numbers accessed by 15 one-touch and 100 coded speed dials. A clear, intuitive 5-line LCD display makes this fax particularly easy to use.
  • More productive working
    Thanks to the 30-page automatic document feeder, users can fax or copy lengthy documents smoothly, in a single operation, rather than feeding them through a page at a time. A 150-sheet capacity paper tray also saves time refilling paper.
  • Fast printing and copying
    Use this fax as a productive 18-page-per-minute laser printer via the USB connection. With Quick First Print technology there is a fast warm-up time from sleep mode. You can also copy documents at 11.8 pages per minute.
  • Simple maintenance
  • Exceptional energy efficiency
    This environmentally friendly fax has class-leading energy efficiency, consuming only 1.5 watts in sleep mode.
Canon i-SENSYS FAX-L150 - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Max Copying Speed
Up to 11.8 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Original Size
127 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0
Office Machine Features
Ultra High Quality (UHQ) image processing
AC 230 V (50/60Hz)
37.2 cm x 30.3 cm x 30.3 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 impressions
Display
5 lines
USB 2.0
Standard Memory
64 MB 64 MB
Copying
Max Copying Speed
Up to 11.8 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
200%
Max Document Reduction
50%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save
Printing
Max Printing Speed
Up to 18 ppm
Printer Drivers / Emulations
UFRII LT
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Max Battery Backup Time
5 minutes
Total Memory Capacity
Up to 512 pages
Fax Printing Speed
Up to 18 ppm
Fax Printing Resolution
1200 x 600 dpi
Handset
Optional
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
15 station(s)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
125 stations
Delayed Transmission
125 stations
Automatic redialing, remote reception, Dual Access, auto reduction
Document & Media Handling
Min Original Size
127 x 139.7 mm
Max Original Size
Original Type
Sheets
30 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
150 sheets
100 sheets
Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 30 sheets size: 127 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 18 ppm - B/W , Copying: up to 11.8 ppm - B/W
1 x USB 2.0
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.4.9 - 10.7.x
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
1.02 kW
Power Consumption Standby
10 Watt
Power Consumption Sleep
1.5 Watt
Warm-Up Time
14 sec
First Copy Out Time B/W
22.3 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages - Canon 728 Starter
ENERGY STAR Certified
37.2 cm
30.3 cm
30.3 cm
8.6 kg
Sound Emission
53 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
89BK Canon MF4410 BLACK TONER In Stock £57.26
