Product
Brand
Canon EOS M3 EF-M 18-55MM Premium Kit
Quicklinx: BCJKWS00 Mfr#: 9694B068
This is a powerful Compact System Camera created for enthusiast photographers who demand premium performance. Fusing Canon's unrivaled image quality and DSLR-levels of control in a compact body, the EOS M3 offers the ability to capture the world around you in exceptional detail. At the heart of the EOS M3 is Canon's first 24.2 megapixel APS-C CMOS sensor and its advanced image processor, DIGIC 6, delivering premium quality stills and Full HD Movies. Combined with super-fast AF performance, thanks to a stunning Hybrid CMOS AF III and 49-point AF System, this camera gives you the freedom to capture the beauty of movement. As an advanced photographer you'll find everything you need at your fingertips, with intuitive DSLR-like dials and control, as well as the flexibility to change your lens, all shrunk down into a compact, ergonomic body to take with you wherever you go.
The EOS M3 incorporates the quintessential EOS design DNA and is instantly comfortable in the palm of your hand thanks to the fluid design grip. Direct access to a range of controls, including an exposure compensation dial, main control dial and customizable buttons, let you adjust the camera's settings to suit your shooting style.
Canon EOS M3 - digital camera EF-M 18-55mm IS STM lens
Digital camera - 1080p - mirrorless system
Lens Included
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
24.2 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 STM Canon EF-M
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical
Camera Flash
Flip-up
Display
LCD display - 3"
Supported Battery
1 x Canon LP-E17 Li-ion rechargeable battery (included)
HDMI, USB 2.0
11.09 cm x 4.44 cm x 6.8 cm
366 g
Lens Included
Enclosure Colour
Sensor Resolution
24.2 Megapixel
Optical Sensor Type
CMOS
Total Pixels
24,700,000 pixels
Effective Sensor Resolution
24,200,000 pixels
Optical Sensor Size
APS-C (14.9 x 22.3mm)
Field of View Crop Factor
1.6
ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
EOS Integrated Cleaning System, Self Cleaning Sensor Unit
Optical Zoom
3x
Image Processor
DIGIC 6
Image Stabiliser
Optical
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
49
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face-priority AF function
Digital Video Format
H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO auto (100-12800), ISO 25600, ISO 100-12800
Exposure Metering
Evaluative, partial (10%), centre-weighted, spot (2%)
Exposure Metering Zones
384
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority, E-TTL II program flash
Shooting Programs
Landscape, portrait mode, close-up, food, sports mode, handheld night shot
Bracketing Modes
Flash Exposure Bracketing
Special Effects
Black & White, Sepia, fisheye, soft focus, monochrome, miniature, HDR, Toy camera, Art Bold, Grainy B&W, Water painting
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, tungsten light, Flash, daylight, shade, fluorescent light (white)
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/3 EV step
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 1-20 (ISO 100)
Lens System
Focal Length Equivalent to 35mm Camera
29 - 88mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
74.3 degree(s)
Zoom Adjustment
Manual
Lens Construction
11 groups / 13 elements
Filter Size
52 mm
Lens Mounting Type
Canon EF-M
Full-time manual focusing, Stepping Motor (STM) technology
Camera Flash
Camera Flash
Flip-up
Guide Number (m / ISO 100)
5
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Flash +/- compensation, flash exposure bracketing
Additional Features
Continuous Shooting Speed
4.2 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
Built-in speaker, auto power save, depth-of-field preview button, sharpness control, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, saturation control, highlight tone priority, contrast control, Auto Lighting Optimizer, peripheral illumination correction, Chromatic Aberration Compensation (CAC), Scene Intelligent Auto technology, noise reduction over long exposures, high ISO speed noise reduction, primary colour filter, Hybrid Auto
Display
3" LCD display
Display Format
1,040,000 pixels
Display Form Factor
Built-in
Touch Screen
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
Microphone (mini-phone stereo 3.5 mm) , USB 2.0 (mini-USB Type B) , HDMI (19 pin mini HDMI Type C)
Software
Software
Canon Digital Photo Professional, Canon Picture Style Editor, Canon EOS Utility, Canon Image Transfer Utility
Carrying strap, battery charger, dust cap, body cap, lens cap, USB cable
Body Material
Stainless steel, magnesium alloy, polycarbonate resin
Battery Type
Canon LP-E17 Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 250 shots (at 23 °C) , Photo shooting - 185 shots (at 0 °C)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
RAW 6000 x 4000 , RAW 5328 x 4000 , RAW 6000 x 3376 , RAW 4000 x 4000 , JPEG 6000 x 4000 , JPEG 5328 x 4000 , JPEG 6000 x 3376 , JPEG 4320 x 2880 , JPEG 4320 x 2432 , JPEG 3840 x 2880 , JPEG 2880 x 1920 , JPEG 2880 x 1616 , JPEG 2560 x 1920 , JPEG 2304 x 1536 , JPEG 2048 x 1536 , JPEG 1920 x 1080 , JPEG 720 x 480 , JPEG 720 x 408 , JPEG 640 x 480 , JPEG 4000 x 4000 , JPEG 2880 x 2880 , JPEG 1920 x 1920 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 - 30 fps , MOV - 1920 x 1080 - 25 fps , H.264 - 1920 x 1080 - 24 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 1280 x 720 - 50 fps , H.264 - 640 x 480 - 30 fps , H.264 - 640 x 480 - 25 fps
11.09 cm
4.44 cm
6.8 cm
366 g
0 - 85%
