Take your first step into interchangeable lens photography with simplicity in front of you and the power of Canon behind you. A compact system camera that combines DSLR performance with effortless portability.
- Canon EOS M10 - digital camera EF-M 15-45mm IS lens
- Product Type
- Digital camera - 1080p - mirrorless system
- Lens Included
- EF-M 15-45mm IS lens
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 6
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 18.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 3x zoom - 15 - 45 mm - f/3.5-6.3 STM Canon EF-M
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 25 cm
- Image Stabiliser
- Optical
- Camera Flash
- Pop-up flash
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E12 Li-ion rechargeable battery (included)
- Interface
- HDMI, USB 2.0
- Black
- 10.8 cm x 3.5 cm x 6.66 cm
- 265 g
- Product Type
- Lens Included
- Enclosure Colour
- Black
- Sensor Resolution
- 18.0 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 18,500,000 pixels
- Effective Sensor Resolution
- 18,000,000 pixels
- Optical Sensor Size
- APS-C (22.3 x 14.9 mm)
- Field of View Crop Factor
- 1.6
- Frame Rate (Max Resolution)
- 30 fps
- ISO (Max)
- 25600
- Native ISO
- 100-12800
- Extended ISO (Max)
- 25600
- Sensor Dust Reduction
- Sensor Features
- EOS Integrated Cleaning System, Self Cleaning Sensor Unit
- Optical Zoom
- 3x
- Image Processor
- DIGIC 6
- Image Stabiliser
- Optical
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast and phase detection
- Auto Focus Points (Zones) Qty
- 49
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Face Detection
- Face-priority AF function
- Digital Video Format
- H.264
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Interface
- HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO auto (100-12800), ISO 25600, ISO 100-12800
- Exposure Metering
- Evaluative, centre-weighted, spot, partial
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, close-up, self-portrait, food, sports mode, handheld night scene
- Special Effects
- Sepia, Neutral, purple, blue, green, fisheye, soft focus, Faithful, monochrome, landscape, portrait, miniature, HDR, Toy camera, Art Bold, Grainy B&W, Water painting, Standard
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, tungsten light, Flash, daylight, shade, fluorescent light (white)
- Shutter Type
- Mechanical electronically-controlled
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±3 EV range, in 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps in 1/3 EV step
- X-sync Speed
- 1/200sec
- Exposure Range
- EV 1-20 (ISO 100)
Lens System
- Focal Length Equivalent to 35mm Camera
- 24 - 72mm
- Focus Adjustment
- Automatic, manual
- 25 cm
- Max View Angle
- 84.3 degree(s)
- Zoom Adjustment
- Manual
- Lens Construction
- 9 groups / 10 elements
- Filter Size
- 49 mm
- Lens Mounting Type
- Canon EF-M
- Full-time manual focusing, Stepping Motor (STM) technology
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 5
- Flash Modes
- Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- Flash +/- compensation
Additional Features
- Continuous Shooting Speed
- 4.6 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- RGB primary colour filter, auto power save, digital image rotation, camera orientation detection, histogram display, highlight tone priority, Auto Lighting Optimizer, peripheral illumination correction, noise reduction over long exposures, high ISO speed noise reduction, Hybrid Auto, Lateral Chromatic Aberration Correction
Display
- 3" LCD display
- Display Format
- 1,040,000 pixels
- Display Form Factor
- Folding
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Wind noise reduction, sensitivity control
- Connector Type
- USB 2.0 (mini-USB Type B) , HDMI (19 pin mini HDMI Type C)
Software
- Software
- Canon Digital Photo Professional, Canon Picture Style Editor, Canon EOS Utility, Canon Image Transfer Utility
- Included Accessories
- Carrying strap, battery charger, dust cap, body cap, lens cap, USB cable
- Battery Type
- Canon LP-E12 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 255 shots (at 23 °C) , Photo shooting - 210 shots (at 0 °C)
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card Included
- No
- Image Storage
- RAW 5184 x 3456 , RAW 4608 x 3456 , RAW 5184 x 2912 , RAW 3456 x 3456 , JPEG 5184 x 3456 , JPEG 4320 x 2880 , JPEG 2880 x 1920 , JPEG 2304 x 1536 , JPEG 720 x 480 , JPEG 4608 x 3456 , JPEG 3840 x 2880 , JPEG 2560 x 1920 , JPEG 2048 x 1536 , JPEG 640 x 480 , JPEG 5184 x 2912 , JPEG 4320 x 2432 , JPEG 2880 x 1616 , JPEG 1920 x 1080 , JPEG 720 x 408 , JPEG 3456 x 3456 , JPEG 2880 x 2880 , JPEG 1920 x 1920 , JPEG 1536 x 1536 , JPEG 480 x 480
- Video Capture
- H.264 - 1920 x 1080 - 30 fps , H.264 - 1920 x 1080 - 24 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 640 x 480 - 30 fps
- 10.8 cm
- 3.5 cm
- 6.66 cm
- 265 g
- 0 °C
- 40 °C
- 0 - 85%
