Canon EOS M10 CSC Camera Kit inc 15-45mm Lens Black
Quicklinx: C2QLWS00 Mfr#: 0584C039AA
Take your first step into interchangeable lens photography with simplicity in front of you and the power of Canon behind you. A compact system camera that combines DSLR performance with effortless portability.
Canon EOS M10 - digital camera EF-M 15-45mm IS lens
Digital camera - 1080p - mirrorless system
Lens Included
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
18.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 15 - 45 mm - f/3.5-6.3 STM Canon EF-M
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
Canon LP-E12 Li-ion rechargeable battery (included)
HDMI, USB 2.0
10.8 cm x 3.5 cm x 6.66 cm
265 g
Lens Included
Enclosure Colour
Sensor Resolution
18.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
18,500,000 pixels
Effective Sensor Resolution
18,000,000 pixels
Optical Sensor Size
APS-C (22.3 x 14.9 mm)
Field of View Crop Factor
1.6
Frame Rate (Max Resolution)
30 fps
ISO (Max)
25600
Native ISO
100-12800
Extended ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
EOS Integrated Cleaning System, Self Cleaning Sensor Unit
Optical Zoom
3x
Image Processor
DIGIC 6
Image Stabiliser
Optical
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
49
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face-priority AF function
Digital Video Format
H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO auto (100-12800), ISO 25600, ISO 100-12800
Exposure Metering
Evaluative, centre-weighted, spot, partial
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, close-up, self-portrait, food, sports mode, handheld night scene
Special Effects
Sepia, Neutral, purple, blue, green, fisheye, soft focus, Faithful, monochrome, landscape, portrait, miniature, HDR, Toy camera, Art Bold, Grainy B&W, Water painting, Standard
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, tungsten light, Flash, daylight, shade, fluorescent light (white)
Shutter Type
Mechanical electronically-controlled
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/3 EV step
X-sync Speed
1/200sec
Exposure Range
EV 1-20 (ISO 100)
Lens System
Focal Length Equivalent to 35mm Camera
24 - 72mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
84.3 degree(s)
Zoom Adjustment
Manual
Lens Construction
9 groups / 10 elements
Filter Size
49 mm
Lens Mounting Type
Canon EF-M
Full-time manual focusing, Stepping Motor (STM) technology
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
5
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Flash +/- compensation
Additional Features
Continuous Shooting Speed
4.6 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
RGB primary colour filter, auto power save, digital image rotation, camera orientation detection, histogram display, highlight tone priority, Auto Lighting Optimizer, peripheral illumination correction, noise reduction over long exposures, high ISO speed noise reduction, Hybrid Auto, Lateral Chromatic Aberration Correction
Display
3" LCD display
Display Format
1,040,000 pixels
Display Form Factor
Folding
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction, sensitivity control
Connector Type
USB 2.0 (mini-USB Type B) , HDMI (19 pin mini HDMI Type C)
Software
Software
Canon Digital Photo Professional, Canon Picture Style Editor, Canon EOS Utility, Canon Image Transfer Utility
Carrying strap, battery charger, dust cap, body cap, lens cap, USB cable
Battery Type
Canon LP-E12 Lithium Ion
Details
Battery Life Details
Photo shooting - 255 shots (at 23 °C) , Photo shooting - 210 shots (at 0 °C)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Memory Card Included
No
Image Storage
RAW 5184 x 3456 , RAW 4608 x 3456 , RAW 5184 x 2912 , RAW 3456 x 3456 , JPEG 5184 x 3456 , JPEG 4320 x 2880 , JPEG 2880 x 1920 , JPEG 2304 x 1536 , JPEG 720 x 480 , JPEG 4608 x 3456 , JPEG 3840 x 2880 , JPEG 2560 x 1920 , JPEG 2048 x 1536 , JPEG 640 x 480 , JPEG 5184 x 2912 , JPEG 4320 x 2432 , JPEG 2880 x 1616 , JPEG 1920 x 1080 , JPEG 720 x 408 , JPEG 3456 x 3456 , JPEG 2880 x 2880 , JPEG 1920 x 1920 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1920 x 1080 - 24 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 640 x 480 - 30 fps
10.8 cm
3.5 cm
6.66 cm
265 g
0 - 85%
