Canon EOS 1300D SLR Camera Kit inc EF-S 18-55mm IS II Lens
Quicklinx: C5LDWS00 Mfr#: 1160C029AA 16GBCASE
Capture superb detailed images thanks to a large 18.0 Megapixel APS-C size sensor. Print your images up to A2 size or creatively crop them and still achieve great quality. Take memorable, atmospheric pictures in low light with a large ISO sensitivity range of ISO 100-6400 (expandable to ISO 12,800), which reduces the need for flash - so you can capture the natural ambience of every precious moment.
Canon EOS 1300D - digital camera EF-S 18-55mm IS II lens
Digital camera - 1080p - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
SD card
Image Processor
DIGIC 4+
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
18.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 IS II Canon EF-S
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Optical - fixed eye-level pentamirror
Display
LCD display - 3"
Supported Battery
Canon LP-E10 Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
12.9 cm x 7.76 cm x 10.13 cm
485 g
Lens Included
Enclosure Colour
Sensor Resolution
18.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
18,700,000 pixels
Effective Sensor Resolution
18,000,000 pixels
Optical Sensor Size
APS-C (22.3 x 14.9 mm)
Field of View Crop Factor
1.6
Frame Rate (Max Resolution)
30 fps
ISO (Max)
12800
Optical Zoom
3x
Image Processor
DIGIC 4+
Image Stabiliser
Optical
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Predictive AI Servo AF
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Auto Focus Features
Predictive Focus Control
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Computer Connectivity
Mac, Windows
Connectivity Features
Remote control via mobile devices, remote live view, Wireless Image Transfer
Exposure & White Balance
Light Sensitivity
ISO 12800, ISO 100-6400, ISO auto (100-6400)
Exposure Metering
Evaluative, partial (10%), centre-weighted
Exposure Metering Zones
63
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, close-up, night portrait, food, sports mode
Special Effects
Neutral, fisheye, soft focus, Faithful, monochrome, landscape, portrait, miniature, Toy camera, Grainy B&W, Standard
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 1-20 (ISO 100)
Lens System
Focal Length Equivalent to 35mm Camera
29 - 88mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
74.3 degree(s)
Zoom Adjustment
Manual
Lens Construction
9 groups / 11 elements
Filter Size
58 mm
Lens Mounting Type
Canon EF/EF-S
Aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
9.2
Flash Modes
Fill-in mode, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation
Additional Features
Continuous Shooting Speed
3 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, auto power save, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, highlight tone priority, GPS ready, highlight point display, Dust Delete Data system, built-in help guide, Auto Lighting Optimizer, peripheral illumination correction, Eye-Fi Card Ready, Scene Intelligent Auto technology, noise reduction over long exposures, high ISO speed noise reduction
Tripod Mount
Connection Point
1/4" socket
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
95%
Optical Viewfinder Magnification
0.8x
Optical Viewfinder Dioptric Correction Range
-2.5 to +0.5
Viewfinder Information
Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status, FE lock, maximum burst, monochrome shooting
Display
3" LCD display
Display Format
920,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output , HDMI output (19 pin mini HDMI Type C)
Software
Software
Drivers & Utilities, Canon Digital Photo Professional, Canon Picture Style Editor, Canon EOS Utility
Battery pack, battery charger, neck strap, USB cable, eyecup, battery cover, power cable
Body Material
Carbon fibre/fibreglass-reinforced polycarbonate resin
Battery Type
Canon LP-E10 Lithium Ion
Details
Battery Life Details
Photo shooting - 500 shots (at 23 °C (AE 50%, FE 50%)) , Photo shooting - 410 shots (at 0 °C (AE 50%, FE 50%))
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card Included
No
Image Storage
RAW 5184 x 3456 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 2592 x 1728 , JPEG 1920 x 1280 , JPEG 720 x 480
Video Capture
MOV - 1920 x 1080 p - 30 fps , MOV - 1920 x 1080 p - 24 fps , MOV - 1280 x 720 p - 60 fps , MOV - 1280 x 720 p - 50 fps , MOV - 640 x 480 p - 30 fps , MOV - 640 x 480 p - 25 fps
12.9 cm
7.76 cm
10.13 cm
485 g
0 - 85%
