Canon EF-S 18-55mm f/3.5-5.6 IS STM
The ideal standard lens for those starting out in DSLR photo and video
An affordable standard zoom lens suited to a variety of subjects. Enjoy smooth, near-silent focusing when shooting video, with STM motor technology and Movie Servo AF. A four-stop Image Stabilizer reduces camera shake.
- Versatile zoom range - great for landscapes, portraits and travel
- Compact lightweight design
- Avoid camera shake with a four-stop optical Image Stabilizer
- STM Motor gives smooth, near-silent focusing when shooting video
- 0.25m close focusing distance
An ideal first step into the DSLR world
Tackle a range of subjects, from landscapes to portraits and action, with a versatile 18-55mm zoom range. Lightweight construction makes this a great everyday lens.
Increased sharpness with four-stop Image Stabilizer
An optical Image Stabilizer reduces the risk of camera shake, enabling hand-held photography in low-light conditions without flash. Use shutter speeds up to four stops longer than normal without blur from camera movement.
Quiet, smooth focusing in movies
STM Motor technology provides near-silent focusing to leave your video soundtrack uninterrupted by noise, and adjusts smoothly and precisely as you shoot.
Designed for great photography
Focus on small subjects, with a closest focusing distance of just 0.25m. A non-rotating front element makes using filters straightforward, and a manual focus ring enables manual override of focusing at any time.
Great image quality, whatever the subject
A Super Spectra Coating is used to reduce flare and improve sharpness, while a seven-bladed aperture provides smooth out-of-focus highlights for a more natural look and feel.
- Canon EF-S zoom lens - 18 mm - 55 mm
- Lens System
- Zoom lens
- Intended For
- Digital SLR
- Mounting Type
- Canon EF/EF-S
- Lens Aperture
- F/3.5-5.6
- Focal Length
- 18 mm - 55 mm
- Optical Zoom
- 3 x
- Min Focus Distance
- 25 cm
- Focus Adjustment
- Automatic, manual
- Lens Construction
- 11 groups / 13 elements
- Special Functions
- Zoom
- Filter Size
- 58 mm
- Length
- 7.52 cm
- 205 g
- Length
- 7.52 cm
- Diameter
- 6.9 cm
- 205 g
Lens System
- Zoom lens
- Special Functions
- Zoom
- Intended For
- Digital SLR
- Focal Length
- 18 mm - 55 mm
- Lens Aperture
- F/3.5-5.6
- Minimum Aperture
- F/22 - f/38
- Focal Length Equivalent to 35mm Camera
- 29 - 88mm
- Optical Zoom
- 3 x
- Magnification
- 0.34
- Image Stabiliser
- Optical
- 25 cm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Manual
- Max View Angle
- 74.3 degree(s)
- Min View Angle
- 27.8 degree(s)
- Lens Construction
- Filter Size
- 58 mm
- Diaphragm Blades
- 7
- Lens Coating
- Super Spectra coating
- Mounting Type
- Canon EF/EF-S
- Internal focusing system, full-time manual focusing, aspherical lens, Stepping Motor (STM) technology
- Included Accessories
- Dust cap, lens cap
