Canon EF-S 18-135mm f/3.5-5.6 IS
The versatile, all-purpose powerful standard zoom lens.
Offering a multi purpose zoom range from wide angle to telephoto, and featuring Canon's 4-stop Image Stabilizer, the EF-S 18-135mm f/3.5-5.6 IS provides complete versatility what ever your needs.
- High power, all-purpose 7.5x, 29-216mm equivalent, EF-S zoom
- 4 stop Image Stabilizer
- Automatic panning and tripod detection
- 0.45m close focusing
- UD and aspherical lenses
- Super Spectra coatings
- 6-blade circular aperture
- Optional lens hood
The multi function zoom lens
Offering a 35mm equivalent effective focal length range of 29-216mm, the EF-S 18-135mm f/3.5-5.6 IS combines the majority of all the most popular focal lengths in one lens. Whether it's a wide angle for landscapes you need, or a telephoto for sports day, the EF-S 18-135mm f/3.5-5.6 IS covers all your requirements.
Image Stabilizer
The EF-S 18-135mm f/3.5-5.6 IS features Canon's 4-stop Image Stabilizer (IS). Ideal for low light conditions when a tripod can't be used, the Image Stabilizer system allows shutter speeds of up to 4 stops slower than normal to be used without causing image blur.
Beauty is not just skin deep
The EF-S 18-135mm f/3.5-5.6 IS also features a textured exterior finish for a sophisticated look and feel that matches your EOS camera.
High speed auto focus
A new DC autofocus motor combined with a high-speed CPU and improved AF algorithm enables quick and accurate auto focus performance.
Canon's Super Spectra lens coating is used to prevent flare and ghosting, which are more prone to occur with digital cameras due to reflection off the image sensor. The use of optimised lens coatings prevent flare and ghosting and ensure excellent color balance and contrast.
Discover creative blur
A 6-blade circular aperture enables you to blur your background creatively. This can be used to enhance portraits by creatively blurring background detail making the subject more striking.
Versatile and powerful zoom
A compact, versatile lens suited to a variety of subjects and ideal for travel photography. A 18-135mm zoom range offers the same angle of view as a 29-216mm lens on a full-frame camera. -
Shoot with AF in movies using STM technology
Movie Servo AF uses STM stepping-motor technology for smooth quiet focusing when shooting video with compatible cameras. -
Image stabilizer for shooting movies and stills
Dynamic Image Stabilizer technology smoothes out vibrations and camera movements when shooting video. Image Stabilizer technology allows hand-held photography in low light without using flash or a tripod. Shutter speeds up to four stops longer than normal may be used without blur from camera shake. -
High speed autofocus
Fast autofocus locks onto subjects quickly and accurately. Full-time manual override is available without changing focus mode. -
Get close to your subject
Focus down to 0.39m at any zoom setting for a close-up view of your subject.
- Canon EF-S zoom lens - 18 mm - 135 mm
- Lens System
- Zoom lens
- Intended For
- Digital SLR, full-frame digital SLR
- Mounting Type
- Canon EF/EF-S
- Lens Aperture
- F/3.5-5.6
- Focal Length
- 18 mm - 135 mm
- Optical Zoom
- 7.5 x
- Min Focus Distance
- 39 cm
- Focus Adjustment
- Automatic, manual
- Lens Construction
- 12 groups / 16 elements
- Special Functions
- Zoom
- Filter Size
- 67 mm
- Length
- 9.6 cm
- 480 g
- Designed For
- EOS 1000, 1100, 20, 30, 300, 350, 40, 400, 450, 50, 500, 60, 600, 650, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Kiss X5, Kiss X50, Rebel T1i, Rebel T3, Rebel T3i, Rebel T4i, Rebel XS, Rebel XSi
- Length
- 9.6 cm
- Diameter
- 7.66 cm
- 480 g
Lens System
- Zoom lens
- Special Functions
- Zoom
- Intended For
- Focal Length
- 18 mm - 135 mm
- Lens Aperture
- F/3.5-5.6
- Minimum Aperture
- F/22 - f/38
- Focal Length Equivalent to 35mm Camera
- 29 - 216mm
- Optical Zoom
- 7.5 x
- Magnification
- 0.28
- Image Stabiliser
- Optical (Dynamic Image Stabilizer)
- 39 cm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Manual
- Max View Angle
- 74.3 degree(s)
- Min View Angle
- 11.5 degree(s)
- Lens Construction
- Filter Size
- 67 mm
- Diaphragm Blades
- 7
- Lens Coating
- Mounting Type
- Canon EF/EF-S
- UD glass, internal focusing system, full-time manual focusing, aspherical lens, zoom lock switch, Stepping Motor (STM) technology
- Designed For
- Canon EOS 1000D, 1100D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 600D, 60D, 60Da, 650D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Kiss X5, Kiss X50, Rebel T1i, Rebel T3, Rebel T3i, Rebel T4i, Rebel XS, Rebel XSi
