Canon EF-S 10- 22 mm f/3.5-4.5 USM Wide Angle Zoom Lens
Quicklinx: 4RK0WS00 Mfr#: 9518A007AA
With its effective focal length range of approximately 16-35mm in 35mm format, the EF-S 10-22mm f/3.5-4.5 USM is a remarkable lens with outstanding image quality that will take your photography into new dimensions and areas of dramatic expression.
The super-wide zoom not only gives you the freedom to get exactly what you want in the shot, it dramatically alters perspective to allow for dynamic expression. The lens allows you to get extremely close to subjects, exaggerating the difference in size between a near object and its background. Creative photographers can use this phenomenon to create excellent separation between subject and background for a strong sense of presence, or for a pan-focus effect with everything from foreground to background sharply in focus.
Canon EF-S wide-angle zoom lens - 10 mm - 22 mm
Lens System
Wide-angle zoom lens
Intended For
Digital SLR, full-frame digital SLR
Mounting Type
Canon EF/EF-S
Lens Aperture
F/3.5-4.5
Focal Length
10 mm - 22 mm
Optical Zoom
2.2 x
Min Focus Distance
24 cm
Focus Adjustment
Automatic, manual
Lens Construction
10 groups / 13 elements
Special Functions
Wide angle, zoom
Filter Size
77 mm
Length
9 cm
385 g
EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Length
9 cm
Diameter
8.4 cm
385 g
Lens System
Special Functions
Wide angle, zoom
Intended For
Focal Length
10 mm - 22 mm
Lens Aperture
F/3.5-4.5
Minimum Aperture
F/22 - f/27
Focal Length Equivalent to 35mm Camera
16 - 35mm
Optical Zoom
2.2 x
Min Focus Distance
24 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
107.5 degree(s)
Min View Angle
63.5 degree(s)
Lens Construction
Filter Size
77 mm
Diaphragm Blades
6
Lens Coating
Multicoated
Mounting Type
Canon EF/EF-S
UD glass, internal focusing system, Ultrasonic Motor (USM), aspherical lens
Canon EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
