With its effective focal length range of approximately 16-35mm in 35mm format, the EF-S 10-22mm f/3.5-4.5 USM is a remarkable lens with outstanding image quality that will take your photography into new dimensions and areas of dramatic expression.
The super-wide zoom not only gives you the freedom to get exactly what you want in the shot, it dramatically alters perspective to allow for dynamic expression. The lens allows you to get extremely close to subjects, exaggerating the difference in size between a near object and its background. Creative photographers can use this phenomenon to create excellent separation between subject and background for a strong sense of presence, or for a pan-focus effect with everything from foreground to background sharply in focus.
- Canon EF-S wide-angle zoom lens - 10 mm - 22 mm
- Lens System
- Wide-angle zoom lens
- Intended For
- Digital SLR, full-frame digital SLR
- Mounting Type
- Canon EF/EF-S
- Lens Aperture
- F/3.5-4.5
- Focal Length
- 10 mm - 22 mm
- Optical Zoom
- 2.2 x
- Min Focus Distance
- 24 cm
- Focus Adjustment
- Automatic, manual
- Lens Construction
- 10 groups / 13 elements
- Special Functions
- Wide angle, zoom
- Filter Size
- 77 mm
- Length
- 9 cm
- 385 g
- Designed For
- EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
- Length
- 9 cm
- Diameter
- 8.4 cm
- 385 g
Lens System
- Special Functions
- Wide angle, zoom
- Intended For
- Focal Length
- 10 mm - 22 mm
- Lens Aperture
- F/3.5-4.5
- Minimum Aperture
- F/22 - f/27
- Focal Length Equivalent to 35mm Camera
- 16 - 35mm
- Optical Zoom
- 2.2 x
- 24 cm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Manual
- Max View Angle
- 107.5 degree(s)
- Min View Angle
- 63.5 degree(s)
- Lens Construction
- Filter Size
- 77 mm
- Diaphragm Blades
- 6
- Lens Coating
- Multicoated
- Mounting Type
- Canon EF/EF-S
- UD glass, internal focusing system, Ultrasonic Motor (USM), aspherical lens
- Designed For
- Canon EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
