Canon EF 70-200mm F/4.0 L IS USM Lens
Quicklinx: 9C7GWS00 Mfr#: 1258B005AA
Canon EF 70-200mm f/4L IS USM
The professional's lightweight IS telephoto zoom.
Compact, manoeuvrable and lightweight. The EF 70-200mm f/4L IS USM is a telezoom featuring the very finest in L-series optical technology to deliver outstanding optical performance and operability.
  • L-series optics
  • Light and compact
  • Four-stop Image Stabilizer
  • Constant f/4 maximum aperture
  • Fluorite and UD lens elements
  • Super Spectra coatings
  • Circular aperture for pleasing background blur
The EF 70-200mm f/4L IS USM features a four-stop Image Stabilizer (IS), making this an ideal lens for handheld work. Shutter speeds up to four stops slower than would otherwise be possible can be used with no perceptible increase in image blur. When panning horizontally, the IS system can be set to correct only for unwanted vertical shake.
L-series quality
The L-series is Canon's flagship professional lens range, representing the best in precision-designed EF optics. L-series lenses combine superior performance with superlative handling, and are resistant to dust and moisture.
Lightweight and compact design
With a physical length of just 172mm, and weighing only 760g, the EF 70-200mm f/4L IS USM is ideal for assignments where there is a need to travel light while maintaining image quality.
Fixed aperture
The maximum f/4 aperture is available at all focal-length settings, meaning exposure settings will not change as the lens is zoomed through its range.
The lens incorporates a single fluorite element and two UD (ultra-low dispersion glass) elements to suppress secondary chromatic aberrations. The result is crisp, high-contrast images, free of distortion and colour fringing.
Ultrasonic focusing
A ring-type ultrasonic motor drives autofocus extremely quickly, and in near silence. Excellent holding torque ensures the point of focus is reached accurately, without overshooting. Furthermore, full-time manual override is available, making it possible to adjust focus without leaving AF mode.
Super Spectra coatings ensure accurate colour balance and enhance contrast. They also reduce flare and ghosting - a common problem caused by light bouncing off a camera's sensor.
Smooth background blur
A virtually circular aperture diaphragm gives out of focus regions a softer, more uniform feel. Sharp foreground objects stand out against a smooth blurred background.
Accessories
A cylindrical bayonet hood and soft case are included.
Canon EF telephoto zoom lens - 70 mm - 200 mm
Lens System
Telephoto zoom lens
Intended For
Digital SLR
Mounting Type
Canon EF
Lens Aperture
F/4.0
Focal Length
70 mm - 200 mm
Optical Zoom
2.9 x
Min Focus Distance
1.2 m
Focus Adjustment
Automatic, manual
Lens Construction
15 groups / 20 elements
Special Functions
Tele, zoom
Filter Size
67 mm
Length
17.2 cm
760 g
EOS 1000D, 1D, 1Ds, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Length
17.2 cm
Diameter
7.6 cm
760 g
Lens System
Telephoto zoom lens
Special Functions
Tele, zoom
Intended For
Digital SLR
Focal Length
70 mm - 200 mm
Lens Aperture
F/4.0
Optical Zoom
2.9 x
Magnification
0.21
Image Stabiliser
Optical
Min Focus Distance
1.2 m
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
34 degree(s)
Min View Angle
12 degree(s)
Lens Construction
Filter Size
67 mm
Mounting Type
Canon EF
UD glass, internal focusing system, full-time manual focusing, rear focusing system, dustproof
Lens hood, soft case, dust cap, lens cap
Canon EOS 1000D, 1D, 1D Mark II, 1D Mark II N, 1D Mark III, 1D Mark IV, 1Ds, 1Ds Mark II, 1Ds Mark III, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 5D Mark II, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
