The lens embodies Canon's highest standards of L-series optics, build quality, reliability and operability. A robust construction includes dust and moisture resistant seals to protect against harsh weather conditions.
A fast f/2.8 aperture delivers impressive low light performance and depth-of-field control. The aperture is fixed over the full focal range, allowing photographers to maintain a constant fast shutter speed when zooming.
A ring USM (Ultrasonic Motor) drives extremely rapid auto focus with near-silent operation. Full time mechanical manual focus override is available without having to switch out of AF. The lens offers a minimum focusing distance of 0.28m throughout the zoom range.
The EF 16-35mm f/2.8L II USM incorporates three aspherical elements to ensure corner-to-corner sharpness and clarity throughout the focal range. Two UD (Ultra Low Dispersion) elements virtually eliminate chromatic aberrations.
Super Spectra lens coatings suppress flare and ghosting - more prone to occur with digital cameras due to reflection off the image sensor. Coatings also help maintain accurate color balance and high contrast.
The lens passes distance information back to the camera's E-TTL II flash system for consistently accurate flash metering.
The EF 16-35mm f/2.8L II USM lens comes supplied with a lens hood and soft case.
- Canon EF wide-angle zoom lens - 16 mm - 35 mm
- Lens System
- Wide-angle zoom lens
- Intended For
- Digital SLR, full-frame digital SLR
- Mounting Type
- Canon EF
- Lens Aperture
- F/2.8
- Focal Length
- 16 mm - 35 mm
- Optical Zoom
- 2.2 x
- Min Focus Distance
- 28 cm
- Focus Adjustment
- Automatic, manual
- Lens Construction
- 12 groups / 16 elements
- Special Functions
- Wide angle, zoom
- Filter Size
- 82 mm
- Length
- 11.2 cm
- 0.64 kg
- Designed For
- EOS 1000D, 1D, 1Ds, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
- Length
- 11.2 cm
- Diameter
- 8.9 cm
- 0.64 kg
Lens System
- Special Functions
- Wide angle, zoom
- Intended For
- Focal Length
- 16 mm - 35 mm
- Lens Aperture
- F/2.8
- Minimum Aperture
- F/22
- Optical Zoom
- 2.2 x
- Magnification
- 0.22
- 28 cm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Manual
- Max View Angle
- 108.2 degree(s)
- Min View Angle
- 63 degree(s)
- Lens Construction
- Filter Size
- 82 mm
- Diaphragm Blades
- 7
- Lens Coating
- Super Spectra coating
- Mounting Type
- Canon EF
- UD glass, Ultrasonic Motor (USM), full-time manual focusing, aspherical lens
- Included Accessories
- Lens hood, dust cap, lens cap, carrying pouch
- Designed For
- Canon EOS 1000D, 1D, 1D Mark II, 1D Mark II N, 1D Mark III, 1D Mark IV, 1Ds, 1Ds Mark II, 1Ds Mark III, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 5D Mark II, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
