Canon EF 16-35mm f/2.8L II USM Lens
Quicklinx: 7LP2WS00 Mfr#: 1910B005AA
The lens embodies Canon's highest standards of L-series optics, build quality, reliability and operability. A robust construction includes dust and moisture resistant seals to protect against harsh weather conditions.
A fast f/2.8 aperture delivers impressive low light performance and depth-of-field control. The aperture is fixed over the full focal range, allowing photographers to maintain a constant fast shutter speed when zooming.
A ring USM (Ultrasonic Motor) drives extremely rapid auto focus with near-silent operation. Full time mechanical manual focus override is available without having to switch out of AF. The lens offers a minimum focusing distance of 0.28m throughout the zoom range.
The EF 16-35mm f/2.8L II USM incorporates three aspherical elements to ensure corner-to-corner sharpness and clarity throughout the focal range. Two UD (Ultra Low Dispersion) elements virtually eliminate chromatic aberrations.
Super Spectra lens coatings suppress flare and ghosting - more prone to occur with digital cameras due to reflection off the image sensor. Coatings also help maintain accurate color balance and high contrast.
The lens passes distance information back to the camera's E-TTL II flash system for consistently accurate flash metering.
The EF 16-35mm f/2.8L II USM lens comes supplied with a lens hood and soft case.
Canon EF wide-angle zoom lens - 16 mm - 35 mm
Lens System
Wide-angle zoom lens
Intended For
Digital SLR, full-frame digital SLR
Mounting Type
Canon EF
Lens Aperture
F/2.8
Focal Length
16 mm - 35 mm
Optical Zoom
2.2 x
Min Focus Distance
28 cm
Focus Adjustment
Automatic, manual
Lens Construction
12 groups / 16 elements
Special Functions
Wide angle, zoom
Filter Size
82 mm
Length
11.2 cm
0.64 kg
EOS 1000D, 1D, 1Ds, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Length
11.2 cm
Diameter
8.9 cm
0.64 kg
Lens System
Special Functions
Wide angle, zoom
Intended For
Focal Length
16 mm - 35 mm
Lens Aperture
F/2.8
Minimum Aperture
F/22
Optical Zoom
2.2 x
Magnification
0.22
Min Focus Distance
28 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
108.2 degree(s)
Min View Angle
63 degree(s)
Lens Construction
Filter Size
82 mm
Diaphragm Blades
7
Lens Coating
Super Spectra coating
Mounting Type
Canon EF
UD glass, Ultrasonic Motor (USM), full-time manual focusing, aspherical lens
Lens hood, dust cap, lens cap, carrying pouch
Canon EOS 1000D, 1D, 1D Mark II, 1D Mark II N, 1D Mark III, 1D Mark IV, 1Ds, 1Ds Mark II, 1Ds Mark III, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 5D Mark II, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
