Canon DR6010C Colour Document Scanner
Quicklinx: 8NM9WS00 Mfr#: 3801B003
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 218 x 356 mm
Interface: SCSI, USB 2.0
Compatibility: PC
£1,304.73 ex VAT
£1,565.67 inc VAT
The imageFORMULA DR-6010C departmental scanner delivers high-speed, reliable document handling and high-quality images in a small package, with a daily duty cycle of 7,500. Flexibility, rich features, and ease-of-use help maximize return on investment at all levels of the business system.
Benefits
  • High speed colour scanning – 60 ppm at 200 & 300dpi
  • Front-Feed design & straight paper path option
  • Large 100 sheet feeding
  • Energy efficient
  • Advanced image processing
  • Robust - duty cycle of 7,500 scans/day
  • Bundled Capture Perfect
Detailed Features
Take a more detailed look into the Canon imageFORMULA DR-6010C
Productivity when it matters
The DR-6010C is our fastest departmental scanner yet, scanning a rapid 60-ppm in colour at resolutions of 200 & 300dpi. A large capacity 100 sheet automatic feeder enables significant batches to be processed, for more scans in less time.
Flexible and reliable feeding
Coupled with the operator appreciated front–feed design the DR-6010C also comes with a selectable straight paper path which can be used for the trouble-free scanning of plastic cards and thick cards up to 546g/m², or more fragile documents.
Energy efficient
The DR-6010C doesn’t just save time, it cuts energy consumption too, being one of the most energy efficient devices in its class.
Optimum quality
A huge range of powerful features such as Auto-Colour Detection, Text Orientation Recognition, Auto Paper Size and Deskew detection ensure superb quality and optimum efficiency.
Small yet built for tough workloads
Despite the DR-6010C being small enough to fit on any desktop it’s capable of taking on busy office requirements quickly and reliably with a suggested daily duty cycle of up to 7,500 scans a day.
User friendly
The DR-6010C can be used across a mixed range of business scanning applications. The Scan-To- Job buttons speed up productivity by allowing batches to be quickly scanned and sent to pre-defined destinations or workflow applications. Canon’s CapturePerfect software is bundled with the DR-6010C, with a Capture Perfect Software Developers Kit (SDK) also available for easy, customised integrations.
  • Speed to suit user needs
    Employees in paper-intensive environments find themselves looking for standards to alleviate the document conversion process. The DR-6010C scanner employs technologies such as an advanced three-line CIS sensor and onboard file compression capabilities, enabling prompt transition of hard-copy documents into electronic files at fast speeds.
  • Flexible capabilities for seamless document handling
    Users with pressing document capture needs not only require fast scanning speeds to lessen their workloads, but they must also reduce preparation time and increase unattended batch scanning time. The DR-6010C scanner exercises a diverse set of features to achieve these goals. With capabilities such as Ultrasonic Double-Feed Detection, straight paper path, and Long Document Mode, the DR-6010C scanner can reliably accommodate a wide variety of documents, including plastic cards, fragile or thick documents, and documents up to 39.4" in length. The DR-6010C scanner is a flexible solution for users with varied batch scanning needs.
  • Dedicated features for detailed image capture
    Canon realizes that within business workflows, users are not able to sacrifice scanning quantity for quality. The DR-6010C scanner concentrates advanced image processing features into a convenient design for precise yet rapid document capture. Scanning at resolutions up to 600 dpi, these models use image processing features such as Prevent Bleed-Through and Moiré Reduction as well as sensor Shading Mechanisms to maintain the integrity of scanned documents, without forfeiting scanning speed.
  • User-friendly solutions for capturing and distributing documents
    Easy integration and user-friendly features are important when deploying scanning solutions into existing corporate workflows. To increase productivity, the DR-6010C scanner yields many user-intuitive features. Scan-To-Job buttons distribute documents directly to e-mail, printer, and other standard destinations, with one-touch access to customizable or preprogrammable scan tasks.
  • Environment in mind
    The DR-6010C scanner has been designed with Canon's initiative to take an environmental approach to product design and life cycle. For example, the scanners can be synchronized to automatically turn on and off, according to the status of the connected PC, and feature a Standby Mode to conserve power. The scanner also meets the ENERGY STAR guidelines for energy efficiency, and also comply with the RoHS and WEEE directives for reduction of hazardous substances and waste products.
Canon imageFORMULA DR-6010C - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
218 x 356 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
218 mm x 1000 mm
Automatic Duplexing
Document Feeder Type
Manual, automatic
Document Storage Capacity
100 sheets
AC 230V (50/60 Hz)
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista
31.8 cm x 27.8 cm x 18.6 cm
6.5 kg
Environmental Standards
ENERGY STAR Qualified
2 Years
Interface Type
USB 2.0, SCSI
218 x 356 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Scanner Speed Details
60 ppm - black & white , 60 ppm - black & white (front) / greyscale (back) , 60 ppm - colour , 120 ipm - duplex - black & white , 120 ipm - duplex - black & white (front) / greyscale (back) , 120 ipm - colour
TWAIN, ISIS
Media Handling
Max Document Size
218 mm x 1000 mm
Manual, automatic
100 sheets
USB 2.0 , SCSI
RoHS
ENERGY STAR Certified
External power adapter
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
30 Watt (2.2 Watt)
Software Included
Drivers & Utilities, Canon CapturePerfect
31.8 cm
27.8 cm
18.6 cm
6.5 kg
Service and Support
2 Years
8NM9 Canon Roller kit for a DR4010C In Stock £54.04
8NM9 Canon Easy Service Plan On-Site Next Day Service Hardware support 3 Years In Stock £695.71
Interface: SCSI
Interface: USB 2.0
Compatibility: PC
Brand: Canon
Price Range Ex VAT: £1000 - £1500
