Canon DR-F120 A4 Colour Document Scanner 20ppm Mono
Quicklinx: B1KRWS00 Mfr#: 9017B003
Type: Document scanner
Form Factor: Desktop
Interface: USB 2.0
Compatibility: PC
49 in stock
£239.99 ex VAT
£287.98 inc VAT
Maximised productivity
Capture various types of document accurately and efficiently with the DR-F120: a compact all-in-one scanning solution that offers both an automatic document feeder (ADF) and flatbed. You can save yourself valuable time using the 50-sheet document feeder, with its faster 20ppm scanning speeds. The DR-F120 can be relied on to get through your work with a suggested daily volume of up to 800 scans.
Effortless paper handling
The DR-F120 gives you complete flexibility to scan a wide range of materials despite its compact body size and small footprint. The straight-through ADF path accommodates A4-width documents, and media of up to 1,000mm in length. You’ll enjoy increased reliability and time-savings when scanning mixed documents with Canon’s dependable separation and feed roller mechanism. The flatbed scanner is ideal for handling media like books, passports or magazines, and effortlessly captures pages up to legal size. It’s equally at home with photos or other thick, thin and delicate documents.
Superior image quality
The DR-F120 delivers superior quality results time after time, due to its 600dpi scanning, wide range of built-in image enhancement features and Canon’s renowned imaging technology. You’ll achieve unprecedented colour accuracy that stays true to the original document via the scanner’s 3-Dimensional Color Correction function.
Simple, user-friendly operation
Achieve superb results with just a single touch of a button using the Full Auto Mode that automatically applies the best settings for each scanned image. Built-in tools eliminate blank pages and automatically detect paper size and text orientation; while the automatic deskew feature straightens documents fed at an angle. Frequent tasks can be made even simpler by assigning them to any of the 3 job buttons on the scanner panel.
Bundled software gives you more choice
The DR-F120 offers a simple and intuitive scanning experience using Canon’s CaptureOnTouch software. Users can scan, edit and send their documents even more easily with this versatile scanning solution. Its step-by-step, icon-based user interface lets users quickly convert their paper documents to multiple file formats (PDF, TIFF, JPEG, BMP, PNG and PowerPoint). CaptureOnTouch is equally capable as a simple document filing solution that lets users scan and create searchable PDF documents – including easy text-based search and retrieval. Cloud plug-ins to SharePoint, SugarSync, OneDrive, Dropbox, Google Drive™ and Evernote are included, ISIS and TWAIN drivers are also provided.
Easy to own and maintain
DR-F120 is easy to maintain because of its user-friendly design. The feed rollers are user-replaceable, which means you won’t incur the cost of calling out a service technician. Your costs stay low due to the scanner’s high energy-efficiency of just 28W in operation.
Canon imageFORMULA DR-F120 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 10 ppm (colour)
Max Document Size
216 mm x 1000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
800 scans per day
AC 230V (50/60 Hz)
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012
Microsoft Certification
Compatible with Windows 7
49.5 cm x 33.5 cm x 20.1 cm
4.6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
10 ppm
Duty Cycle
800 scans per day
Scanner Speed Details
20 ppm - black & white - A4 - 200 dpi , 36 ipm - duplex - black & white - A4 - 200 dpi , 10 ppm - colour - A4 - 200 dpi , 18 ipm - duplex - colour - A4 - 200 dpi
Scanner Features
Color Dropout, Shadow Removal, Double feed detection, Error Diffusion, Moire Reduction, automatic colour detection, automatic page size detection, blank page skipping, MultiStream Technology, Advanced Text Enhancement, Rapid Recovery System, Text Orientation Recognition, Punch Hole Removal, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Character Emphasis, Deskew, Edge Emphasis, Preset Gamma Curve, Color Enhancement, Long Document Scanning, Border Removal, Erase Dot, Erase Notch, Flatbed detection
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 1000 mm
Plain paper
Automatic
50 sheets
USB 2.0
RoHS
ENERGY STAR Certified
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
19.9 Watt
Power Consumption Sleep
2.5 Watt
Software Included
Drivers & Utilities, EMC Captiva Cloud Runtime Controls, Canon CaptureOnTouch 3
49.5 cm
33.5 cm
20.1 cm
4.6 kg
10 °C
32.5 °C
20 - 80%
Interface: USB 2.0
Compatibility: PC
Brand: Canon
Price Range Ex VAT: 150 - 300
