Easily integrate information into workflows with the Canon imageFORMULA DR-C130 document scanner. It reliably converts paper-based documents into high-quality digital images, and its compact footprint makes it ideal for any office environment.
Fast, productive scanning
High speed scanning at up to 30ppm/60ipm is achieved in both colour and B&W thanks to the Canon’s innovative CMOS contact image sensor and high brightness LED technology. The ability to scan duplex documents at a single pass will accelerate your document workflows while a 50 sheet document feeder lets you maintain a high level of productivity. The DR-C130 is up to 50% more energy efficient than its competitors in the market.
Easy to use
The front panel operation makes it easy to stop, start and resume scanning with a touch of a button. You can also register scan jobs using CaptureOnTouch software, and assign a job to the start button to allow for a quick execution of frequent scanning operations. CaptureOnTouch also incorporates a Full-Auto Mode function, which automatically applies the best settings to scan jobs saving you time.
Maintain exceptional productivity
The DR-C130 conveniently handles a variety of media from embossed card to long sheets up to 3m in length. The scanner's three-way tray design lets you scan with the eject tray; closed, opened or half-opened providing versatility where desk space is at a premium. Reliable scanning is also achieved with the convenient double feed release system lets the user to ‘ignore and continue’ scan jobs, in special cases when scanning an envelope or document with a sticky note attached.
Advanced image quality
The DR-C130 comes with a variety of image processing features to help you achieve outstanding quality results every time. Features such as deskew, skip blank page and text orientation recognition enable precise and accurate image reproduction.
Seamless cloud connectivity
You can scan and save documents directly to cloud applications including SharePoint, Evernote and Google Docs. Information can then be retrieved using your smart phone or PC. An EMC Captiva Cloud Capture Run Time module is also available for the DR-C130, making it possible for developers to effortlessly create web-based scanning applications.
Full-suite of ‘out the box’ software
The DR-C130 comes with a full range of premium software to help you produce highly professional scanning results and create, edit and manage document workflows. This includes CaptureOnTouch, CapturePerfect, BizCard, OmniPage, PaperPort, eCopy PDF Pro Office and Kofax VRS.
- Canon imageFORMULA DR-C130 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CMOS / CIS
- Light Source
- RGB LED array
- Max Supported Document Size
- Legal (216 x 356 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 30 ppm (mono) / 30 ppm (colour)
- Max Document Size
- 216 mm x 3000 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 2000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista
- Microsoft Certification
- Compatible with Windows 7
- 29.8 cm x 16 cm x 16 cm
- 1.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- CMOS / CIS
- Bulb / Light Source Type
- RGB LED array
- Max Document Scan Speed B/W
- 30 ppm
- Max Document Scan Speed Colour
- 30 ppm
- Duty Cycle
- Scanner Speed Details
- 30 ppm - portrait B&W - A4 - 200 dpi , 60 ipm - duplex - portrait B&W - A4 - 300 dpi , 30 ppm - portrait colour - A4 - 200 dpi , 60 ipm - duplex - portrait colour - A4 - 200 dpi , 15 ppm - portrait colour - A4 - 300 dpi , 30 ipm - duplex - portrait colour - A4 - 300 dpi
- Scanner Features
- Color Dropout, Ultrasonic Double Feed Detection, Bleed-through reduction, Shadow Removal, Moire Reduction, automatic colour detection, automatic page size detection, blank page skipping, MultiStream Technology, Auto Deskew, automatic resolution setting
Media Handling
- Max Document Size
- 216 mm x 3000 mm
- Plain paper
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 15 Watt (1.8 Watt)
- Software Included
- Drivers & Utilities, Presto! BizCard Reader, Canon CapturePerfect, Kofax VirtualReScan, Canon CaptureOnTouch, Nuance PaperPort, Nuance OmniPage, Nuance eCopy PDF Pro Office
- OS Required
- 29.8 cm
- 16 cm
- 16 cm
- 1.8 kg
