The Canon Connect Station CS100 is your go-to photo and video hub that lets you share, store, view and manage your most memorable moments. The Connect Station CS100 gives you lots of wirelessly accessible storage with the capacity for approximately 150,000 photos or approximately 70 hours of video content . Transferring photos and videos to the Connect Station CS100 is as easy as tapping it with your NFC-equipped Canon camera or camcorder, using the available SD/CF card slots and USB connection, or through a web browser from your smartphone, tablet and PC. Once loaded onto the Connect Station CS100, your photos and videos are automatically organized by date or shooting device, and you can quickly access and enjoy your photos and videos. Best of all, the Connect Station CS100 can play its contents on your HDTV via an HDMI cable, so reliving special memories is fun and comfortable even for large groups, and effortless enough for everyday fun. You can even wirelessly share photos and video between two Connect Station CS100s in different locations to give everyone a way to see family pictures and videos regularly and comfortably on their large-screen TVs.
NFC and Wi-Fi connectivity
The Canon Connect Station CS100 makes wireless transfer of your photos and videos easy and convenient. Simply tap an NFC-equipped Canon camera or camcorder to the Connect Station CS100 to automatically import photos and videos. For easy transfer from other compatible cameras and camcorders, a USB connection and SD/CF card slots are also available. -
Connect to your HDTV
Sharing photos and videos is fun anytime, and especially at family events, but passing around a camera or smartphone, or gathering around a tablet or PC isn't ideal. The Canon Connect Station CS100 connects to your HDTV with an HDMI cable, so you and your family can sit comfortably in front of your HDTV as you show your photos and video in crisp, clear Full HD. Your full resolution photos are breathtaking on a big screen, and (unlike with some devices) even the high bit-rate videos play smoothly. By giving your photos and videos a seamless pathway from your Canon cameras and camcorders to your HDTV, the Connect Station CS100 provides your family a new way to relive memories and interact with today's imaging technologies. Control is easy with the included Remote Control CS-RC1. -
User-friendly menus
With the Canon Connect Station CS100, you can finally have all your photos and videos in one central location, organized for easy retrieval. The Connect Station CS100 automatically sorts files by date (month/year) or shooting device. Simple menus make it easy to create albums as you like, so you'll always be able to access the photos or videos you want. -
Connectivity with compatible wireless printers
You can print photos wirelessly from the Canon Connect Station CS100. The Connect Station CS100 is fully compatible with PictBridge (Wireless LAN)-enabled PIXMA, SELPHY and other printers, so creating that special keepsake is simple and convenient. -
Web browser viewing/transfer
The Canon Connect Station CS100 is designed to make image access and management convenient. Using a web browser, you can view, upload or download photos to and from the Connect Station CS100 right from your smartphone, tablet or PC. For added ease and convenience, compatible Android devices automatically connect you to a web browser without having to manually launch it yourself. From there, you can choose to import your photos. -
Multiple file format support
The Canon Connect Station CS100 accepts photos and videos in various file formats, making it the ideal central storage/sharing/viewing hub. Whether your file is a JPEG, RAW?, MP4, MOV or AVCHD, the Connect Station will support it.
- Canon Connect Station CS100 - digital multimedia receiver
- Product Type
- Digital multimedia receiver
- Audio Channels
- Stereo
- Source
- Network, USB-host, flash memory card, HDD
- Storage
- Hard disc drive 1 TB
- Video Formats
- MPEG-4, AVCHD, MOV
- Photo Formats
- JPEG, RAW
- Supported Resolutions
- 1920 x 1080
- Ethernet, Gigabit Ethernet, Fast Ethernet, Wi-Fi
- Power
- AC 120/230 V (50/60 Hz)
- 15.56 cm x 15.56 cm x 5.11 cm
- 570 g
- Product Type
Audio System
- Audio Channels
- Stereo
- Functions
- Digital player, network player
- Source
- Video Formats
- Photo Formats
- JPEG, RAW
- 1920 x 1080
- Near Field Communication (NFC)
- Storage
- Hard disc drive - 1 TB
Network & Internet Multimedia
- Connectors
- LAN (RJ-45) , HDMI output (19 pin HDMI Type A) , USB 2.0 (4 PIN USB Type A)
- Supported Flash Memory Cards
- SDHC, SD Memory Card, CompactFlash, SDXC
- Included Accessories
- AC power adaptor, AAA battery, remote control
- Voltage Required
- 10 Watt
- Power Consumption Stand by
- 9.5 Watt
- 15.56 cm
- 15.56 cm
- 5.11 cm
- 570 g
