Product
Canon CanoScan LiDE220 A4 Flatbed Scanner
Cloud connectivity!
Quicklinx: 9Q66WS00 Mfr#: 9623B010AA
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: 216 x 297 mm
Interface: USB 2.0
Compatibility: Mac, PC
More than 50 in stock
£61.08 ex VAT
£73.29 inc VAT
The CanoScan LiDE220 Color Image Scanner offers advanced features, easy operation and "Send to Cloud" functionality. The LiDE220 lets you upload images to the Cloud with remarkable ease. Providing a maximum optical resolution of 4800 x 4800 dpi, its vivid 48-bit color depth is capable of producing over 281 trillion possible colors. An Auto Document Fix feature automatically produces beautiful scans with advanced image analysis and area-by-area data correction, while Auto Scan Mode automatically evaluates the item being scanned and saves it with the appropriate settings. The LiDE220 scanner also helps you work efficiently with five EZ Buttons that enable you to scan, copy, Send to Cloud, or create a single or multipage PDF in a snap. It scans fast too, creating a letter-sized color scan in approximately 10 seconds. Plus, it comes with a stand to enable vertical scanning - accommodating workspaces of just about any size. And the Advanced Z-Lid Expansion Top extends up approximately one-inch and over the platen to let you scan large items, such as textbooks or other thick documents. The LiDE220 scanner uses one USB cable for both data and power, so plugging in is easy. The LiDE 220 includes My Image Garden, a convenient software package that makes organizing your photos fun and easy.
  • Excellent resolution
    This product has 4800 x 4800 dpi maximum optical color resolution, 48-bit color depth with over 281 trillion possible colors and 19,200 x 19,200 (Interpolated) software enhanced scans.
  • High speed scan
    It delivers a letter size color scan in approx. 10 seconds.
  • EZ buttons
    There are five buttons that enable you to scan, copy, Send to Cloud or create PDFs faster.
  • Auto document fix
    It automatically employs area-by-area correction for beautiful, easy-to-view scans.
  • Auto scan mode
    It automatically recognizes the type of original, then scans and saves with suitable settings with one click of the Scan button.
  • Advanced Z-Lid expansion top
    It lifts approximately one-inch to scan large items such as personal notebooks and other thick documents.
  • Send to cloud
    It gives an easy way to send all your data or attachments to Dropbox or Evernote with a single button.
  • Hi-speed USB
    You can just plug the cable into your PC for a super-fast connection for your data transfers.
Canon CanoScan LiDE220 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
4800 dpi x 4800 dpi
Interpolated Resolution
19200 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper
Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8.1
Microsoft Certification
Compatible with Windows 7
25 cm x 36.5 cm x 3.9 cm
1.6 kg
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
4800 dpi x 4800 dpi
19200 dpi
Scan Element Type
Bulb / Light Source Type
RGB LED array
Scanner Speed Details
10 sec/scan - colour - A4 - 300 dpi
Scanner Features
Powered by USB port, 5 EZ Buttons, Auto Document Fix, Auto Photo Fix
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper
USB 2.0
Power Consumption Operational (Standby)
2.5 Watt
Power Consumption Stand by
1.4 Watt
Software Included
Drivers & Utilities, Canon Scanning Utility, My Image Garden
25 cm
36.5 cm
3.9 cm
1.6 kg
5 °C
35 °C
10 - 90% (non-condensing)
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Canon
Price Range Ex VAT: 50 - 100
