Canon A1 Large Format Printer  (Roll) -0:42sec 2400 x 1200 dpi 1yr
Quicklinx: BY26WS00 Mfr#: 9854B003AA
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
The Canon imagePROGRAF iPF670 24-inch large format printer is an affordable model for entry-level users. The iPF670 is the printer for your poster and signage needs. The optimal color profile and magenta ink will create the vivid and impactful image you need. Canon understands speed is important, that is why the iPF670 printer is capable of producing an A1 (23.4" x 33.1") print in up to 28 seconds using Economy Mode! The included Sub-ink tank system allows you to use all of the ink in the tank before replacing it, as well as replacing an empty ink tanks on-the-fly without stopping a job mid-print and sacrifice print quality.
  • Dye/pigment reactive ink set
    The 5-Color ink set (cyan, magenta, yellow, black, matte black) found in the imagePROGRAF iPF670 printer is ideal for technical applications. This ink technology utilizes four highly colorfast dye inks for producing bold, expressive color, plus two channels of pigment matte black ink for printing precise lines, smooth curves and small text on technical and office documents. Included is a reformulated magenta ink that helps produce a wider color gamut in the red and orange spectrums, compared to previous models. Canon inks provide superb adhesion to media, scratch and marker resistance and help ensure minimal "bleeding" between colors and text. Even small text printed on colored backgrounds or on uncoated technical papers is crisp and legible on an imagePROGRAF printer.
  • High speed printing
    The imagePROGRAF iPF670 printer has the ability to output an A1 (23.39" x 33.11") sized drawing in Draft mode in approximately 28 seconds! When you need to keep projects moving forward and meet deadlines, this kind of speed is critical. Powering these incredible print speeds is Canon's L-COA (Large Format Printer Common Architecture) print controller, driving the imagePROGRAF print engine to lay down ink with exceptional speed and precision. This high-speed processor enables the print system to process large volumes of data while optimizing output of complex high-color GIS images and architectural renderings for maximum readability and color accuracy.
  • Sub-ink tank system
    Canon's Sub-ink tank system allows all of the available ink in a tank to be used before having to replace it, helping eliminate any wasted ink. The empty tanks can also be replaced on-the-fly without stopping the printer. This is extremely useful during long print jobs.
  • Economy print mode
    The Economy print mode helps reduce the total ink consumption. This feature regulates the use of all inks to produce quick check plots to help minimize your cost per print.
  • Precision printing: high-density PF-04 print head
    Engineered for speed and advanced image production, this printer boasts Canon's print-head technology that lays down ink with exceptional speed and accuracy. The PF-04 print head incorporates a nozzle orifice shape to help minimize mist spray, producing clean lines and text. The high-precision, high-density print head, with a total of 15,360 nozzles, lays down 4 picoliter-size ink droplets that produce sharp detail and excellent image quality. The result is consistently accurate 2400 x 1200 dpi output with fine lines that are accurate to ±0.10% and as thin as 0.02mm.
  • Status Monitor
    The imagePROGRAF Status Monitor display will check the printer's status in real time, allowing you to manage print jobs, media and monitor ink levels. Status Monitor includes an Ink Purchase Notification Function that will notify you when the ink is low and provides you with a link to a website where the tank can be purchased, or the contact information to a trusted supplier. What appears exactly can be selected depending on your preference.
  • Accounting Manager
    Canon imagePROGRAF Accounting Manager tracks how much ink and media is being consumed while printing. Costs can be assigned to ink and paper to determine expenses based on "Cost of goods". You can also input a variable cost that will be added to the total of the cost per print. The data is exportable to a .csv format for Microsoft Excel, from there the data can be used for billing purposes.
Canon imagePROGRAF iPF670 - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
46 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
5-ink - cyan, magenta, yellow, black, matte black x 2
Max Media Size
Roll A1 (61.0 cm)
Min Media Size (Custom)
203.2 mm
Max Media Size (Custom)
610 mm
Print Speed
Up to 0.47 min/page - draft - A1 (594 x 841 mm) , Up to 0.7 min/page - normal - A1 (594 x 841 mm)
Max Resolution (Colour)
2400 x 1200 dpi
USB 2.0, Gigabit LAN
RAM Installed (Max)
256 MB
Language Simulation
HP RTL, HP GL/2, GARO
Media Type
Plain paper, coated paper
Print server
Printer Features
Borderless printing
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2003 R2 (32/64-bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows XP 32-bit, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.6.8 - 10.10.x
99.7 cm x 69.8 cm x 50.7 cm
Printer Type
Printer
Inkjet Technology
Nozzle Configuration
5120 nozzles (matte black), 4 x 2560 nozzles (cyan, magenta, yellow, black)
Minimum Ink Droplet Size
4 pl
Ink Cartridge Configuration
6 individual ink tanks
Ink Type
Canon LUCIA pigment ink
Print Speed
Built-in Devices
Status LCD
Wired
2400 x 1200 dpi
Direct Printing Specifications
Canon Direct Print
Language Simulation
Printer Features
Borderless printing
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Max Media Size
Roll A1 (61.0 cm)
203.2 mm
610 mm
Media Sizes
Roll A2 (42 cm), Roll A3, Roll (25.4 cm), Roll (43.2 cm), Roll (30 cm), Roll (35.6 cm), Roll A1 (59.4 cm), Roll (61 cm), Roll B4, Roll B2
Max Printing Length
18 m
Media Thickness Range
0.07 mm - 1.5 mm
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
3-inch spindle adapter kit
Consumables Included
1 x ink tank (dye-based cyan) - 90 ml , 1 x ink tank (dye-based magenta) - 90 ml , 1 x ink tank (dye-based yellow) - 90 ml , 1 x ink tank (dye-based black) - 90 ml , 2 x ink tank (pigmented matte black) - 90 ml , 1 x printhead - Canon PF-04
Media Included
A2 calibration sheet
Power supply - internal
Frequency Required
50/60 Hz
140 Watt
Software Included
Drivers & Utilities, PosterArtist Lite
15 °C
30 °C
10 - 80% (non-condensing)
Sound Emission (Idle)
35 dB
Sound Emission (Operating)
46 dB
99.7 cm
69.8 cm
50.7 cm
46 kg
