Canon 9000F MKII Flatbed Scanner
Quicklinx: 8T7CWS00 Mfr#: 6218B008AA
Enjoy high-speed scanning for everything from photos to documents, to even 35 mm film while also enjoying superb quality. The CanoScan 9000F Mark II Color image scanner is a high-speed scanner with professional film scanning quality. The CanoScan 9000F Mark II features Super Toric lens, delivering pin-sharp scans from edge-to-edge and bright, low noise images. In addition, its fare level 3 feature provides dust and scratch removal, along with fading, grain and backlight correction. Plus, its auto scan mode automatically adjusts settings by detecting what you're scanning.
  • Speed and quality
    Superb scanning resolution: when you combine 9600 x 9600 maximum color resolutions with a vivid 48-bit color depth and over 281 trillion possible colors, the results will astound you.
  • USB 2.0 Hi-Speed
    Scan and transfer images to your computer at the fastest possible scanning speeds with this connection. The USB 2.0 Hi-Speed interface also allows for quick previews of your images to your computer.
Canon CanoScan 9000F Mark II - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Light Source
White LED
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
48-bit colour / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
9600 dpi x 9600 dpi
Interpolated Resolution
19200 dpi x 19200 dpi
Scan Speed
7 sec / scan
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, slides, film, photo
Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits) SP1, Windows 8, Apple MacOS X 10.6.8 - 10.8
Microsoft Certification
Compatible with Windows 7
27 cm x 48 cm x 11.1 cm
4.6 kg
2 Years
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth
48-bit colour
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
9600 dpi x 9600 dpi
CCD
Bulb / Light Source Type
White LED
Scan Speed
7 sec / scan
Control Panel Buttons Functions
Copy, email, AutoScan, Scan-to-PDF
Scanner Speed Details
7 sec/scan - colour - A4 - 300 dpi
Scanner Features
Film Automatic Retouching and Enhancement (FARE) Level 3, Auto Document Fix, 7 EZ Buttons
Media Handling
Max Document Size
216 mm x 297 mm
USB 2.0 - Type B
Film adaptor
1 x USB cable
Internal power supply
Power Consumption Operational (Standby)
15 Watt (0.9 Watt)
Software Included
Drivers & Utilities, ScanGear, My Image Garden
27 cm
48 cm
11.1 cm
4.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
Service and Support
2 Years
