Canon 270EX II Speedlite Flashgun
Quicklinx: 9V39WS00 Mfr#: 5247B003AA
The ultra-lightweight Canon 270EX II Speedlite is a compact, high-performance flash unit designed for the evolving EOS enthusiast. Developed for fun and easy flash shooting, when used with select Canon EOS DSLR cameras that have a master function, the Speedlite 270EX II can be used as a versatile wireless slave flash. This Speedlite can also be used with other compact digital camera models equipped with a dedicated flash shoe mount. User-friendly in both function and design, the 270EX II Speedlite flash's tele/wide function easily and elegantly allows adjustment of illumination angle and guide number to match shooting conditions. On your photographic journey, the Canon 270EX II Speedlite is primed to be there at every step.
  • Lightweight compact design
    The Canon Speedlite 270EX II's compact design means it will find a space even in the small of kit bags.
  • High power output
    Despite its diminutive size, the Speedlite 270EX II has plenty of power, with a guide number of 27 (m, ISO100) allowing long-range flash photography. E-TTL II metreing with compatible cameras gives accurate flash exposure in all situations, even when bouncing light from a wall or ceiling.
  • Bounce flash head
    A bounce head allows the Speedlite 270EX II's flash output to be bounced off the ceiling for soft, shadowless lighting.
  • Easy to use off-camera flash
    The Speedlite 270EX II can be triggered remotely by a compatible camera or Speedlite flash and is as easy to use in off-camera mode as it is in the hotshoe, opening up countless creative lighting opportunities.
  • Remote shooting
    Experiment with different lighting positions quickly and easily by using the remote release button to trigger the camera remotely from up to 5 m away, whilst you adjust the lighting.
  • Zoom head
    Match the coverage of the Speedlite 270EX II's output to a lens' angle of view by adjusting its zoom head to either the 28 mm or 50 mm setting.
Canon Speedlite 270EX II - hot-shoe clip-on flash
Camera Flash
Hot-shoe clip-on flash
6.6 cm x 7.7 cm x 6.5 cm
155 g
Guide Number (m / ISO 100)
27
Lens Coverage
28mm - 50mm
Supported Exposure Control
E-TTL, E-TTL II
AF illuminator, wireless off-camera control, modelling flash capability, slave function
Required Battery
2 x battery - AA type
Canon XC10; EOS 100, 1200, 1300, 1D, 200, 2000, 250, 4000, 5D, 70, 77, 7D, 80, 800, 850, 90, 9000, Kiss X10, Kiss X7, Kiss X70, Kiss X80, Kiss X9, Kiss X90, Kiss X9i, M2, M3, M5, M6, R5, R6, Ra, Rebel SL2, Rebel SL3, Rebel T100, Rebel T6, Rebel T7, Rebel T7+, Rebel T7i, Rebel T8i; PowerShot G1, SX60
6.6 cm
7.7 cm
6.5 cm
155 g
Camera Flash
27
Lens Coverage
28mm - 50mm
E-TTL, E-TTL II
Vertical Rotation Angle
+90 / 0
Manual Power Control Levels
1/1, 1/64, 1/2, 1/4, 1/8, 1/16, 1/32
Auto Shut-Off
Power Consumption
Recycling time - 0.1 - 3.9 sec with 2 x AA type - Alkaline
Required Battery
Canon XC10 , Canon EOS 100D, 1200D, 1300D, 1D X, 1D X Mark III, 2000D, 200D, 250D, 4000D, 5D Mark IV, 650D, 70D, 77D, 7D Mark II, 800D, 80D, 850D, 9000D, 90D, Kiss X10, Kiss X10i, Kiss X7, Kiss X70, Kiss X80, Kiss X9, Kiss X90, Kiss X9i, M2, M3, M5, M6 Mark II, R5, R6, Ra, Rebel SL2, Rebel SL3, Rebel T100, Rebel T4i, Rebel T5, Rebel T6, Rebel T7, Rebel T7+, Rebel T7i, Rebel T8i , Canon PowerShot G1 X Mark III, SX50 HS, SX60 HS
