Canon 1124C003AA  24" Colour Ink-Jet Large Format Printer
Quicklinx: FCY5WS00 Mfr#: 1124C003AA
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
For the very best photographic print quality, the imagePROGRAF PRO-2000 can produce images with the best print quality, outstanding speed and reliability.
  • Advanced precision print head
    The imagePROGRAF PRO series is fully integrated print head enables even faster printing with exceptional print quality. At a compact wide, enabling efficient, high-precision ink ejection without discrepancies.
  • Image processing engine
    imagePROGRAF PRO series printers feature a re-designed processing engine: L-COA PRO. It combines the latest and most advanced Canon image-handling algorithms with a newly-developed, application-specific integrated circuit (ASIC) for processing high resolution images and data - delivering the very best print quality at high speed.
  • Rigid platform for best quality
    imagePROGRAF PRO series printers feature a brand mechanical platform. The highly innovative chassis structure provides an exceptionally rigid frame that can maintain a precise distance between the print head and media - virtually eliminating oscillation for high-precision ink placement with little inter-color discrepancy.
  • Dual roll unit
    The optional dual roll unit provides either additional paper roll or functions as a media take-up unit for printed output. Media take-up can be performed with the printed surface either on the inside or on the outside.
  • Chroma optimizer
    imagePROGRAF PRO series printers use transparent Chroma Optimizer ink to improve high quality print performance on gloss papers.
  • Color calibration
    Consistent color reproduction is achieved between print jobs, compensating for any variation due to differences among printers or changes over time.
  • Crystal-fidelity output quality
    The full structure, clarity and texture of photographs shot using Canon's EOS digital cameras can be faithfully reproduced on paper, in unique Crystal-fidelity quality, using Canon's Print Studio Pro plug-in.
Canon imagePROGRAF PRO-2000 - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
101 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
12-ink - black, matte black, cyan, magenta, yellow, photo cyan, photo magenta, grey, photo grey, red, blue, chroma optimiser
Max Media Size
Roll A1 (61.0 cm)
Min Media Size (Custom)
203.2 mm
Max Media Size (Custom)
610 mm
Max Resolution (Colour)
2400 x 1200 dpi
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
RAM Installed (Max)
3 GB
Hard Drive
320 GB
Language Simulation
PDF 1.7, SG Raster (Swift Graphic Raster)
Media Type
Plain paper, glossy photo paper, CAD tracing paper, CAD translucent matte film, coated paper, glossy paper
Print server
Printer Features
Borderless printing
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.7.5 - 10.11
111 cm x 98.4 cm x 116.8 cm
Printer Type
Printer
Inkjet Technology
Nozzle Configuration
18432 nozzles
Minimum Ink Droplet Size
4 pl
Ink Cartridge Configuration
12 individual ink tanks
Ink Type
Canon LUCIA PRO pigment ink
Built-in Devices
3.5 inch LCD touch screen
Wireless
2400 x 1200 dpi
Language Simulation
Printer Features
Borderless printing
RAM
RAM Installed (Max)
3 GB
Storage
Hard Drive
320 GB
Media Handling
Media Type
Max Media Size
Roll A1 (61.0 cm)
203.2 mm
610 mm
Media Sizes
Roll A2 (42 cm), Roll (25.4 cm), Roll (40.6 cm), Roll (43.2 cm), Roll (20.3 cm), Roll (30 cm), Roll (32.9 cm), Roll (51.5 cm), Roll (35.6 cm), Roll A1 (59.4 cm), Roll (61 cm), Roll (25.7 cm), Roll A3 (29.7 cm)
Max Printing Length
18 m
Media Thickness Range
0.07 mm - 0.8 mm
Print server
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
3-inch spindle adapter kit
Consumables Included
1 x ink tank (pigmented black) - 160 ml , 1 x ink tank (pigmented matte black) - 160 ml , 1 x ink tank (pigmented cyan) - 160 ml , 1 x ink tank (pigmented magenta) - 160 ml , 1 x ink tank (pigmented yellow) - 160 ml , 1 x ink tank (pigmented photo cyan) - 160 ml , 1 x ink tank (pigmented photo magenta) - 160 ml , 1 x ink tank (pigmented grey) - 160 ml , 1 x ink tank (pigmented photo grey) - 160 ml , 1 x ink tank (pigmented red) - 160 ml , 1 x ink tank (pigmented blue) - 160 ml , 1 x ink tank (pigmented chroma optimiser) - 160 ml , 1 x printhead , 1 x maintenance cartridge
TUV, CB, RoHS, EAC
Power supply - internal
Frequency Required
50/60 Hz
88 Watt
Power Consumption Stand by
1.8 Watt
Software Included
Drivers & Utilities, PosterArtist Lite, Quick Utility Tool Box
Environmental Standards
ENERGY STAR
15 °C
30 °C
10 - 80% (non-condensing)
Sound Emission (Idle)
35 dBA
Sound Emission (Operating)
48 dBA
111 cm
98.4 cm
116.8 cm
101 kg
Width (Shipping)
132.4 cm
Depth (Shipping)
90.2 cm
Height (Shipping)
104.2 cm
Weight (Shipping)
129 kg
