For the very best photographic print quality, the imagePROGRAF PRO-2000 can produce images with the best print quality, outstanding speed and reliability.
Advanced precision print head
The imagePROGRAF PRO series is fully integrated print head enables even faster printing with exceptional print quality. At a compact wide, enabling efficient, high-precision ink ejection without discrepancies. -
Image processing engine
imagePROGRAF PRO series printers feature a re-designed processing engine: L-COA PRO. It combines the latest and most advanced Canon image-handling algorithms with a newly-developed, application-specific integrated circuit (ASIC) for processing high resolution images and data - delivering the very best print quality at high speed. -
Rigid platform for best quality
imagePROGRAF PRO series printers feature a brand mechanical platform. The highly innovative chassis structure provides an exceptionally rigid frame that can maintain a precise distance between the print head and media - virtually eliminating oscillation for high-precision ink placement with little inter-color discrepancy. -
Dual roll unit
The optional dual roll unit provides either additional paper roll or functions as a media take-up unit for printed output. Media take-up can be performed with the printed surface either on the inside or on the outside. -
Chroma optimizer
imagePROGRAF PRO series printers use transparent Chroma Optimizer ink to improve high quality print performance on gloss papers. -
Color calibration
Consistent color reproduction is achieved between print jobs, compensating for any variation due to differences among printers or changes over time. -
Crystal-fidelity output quality
The full structure, clarity and texture of photographs shot using Canon's EOS digital cameras can be faithfully reproduced on paper, in unique Crystal-fidelity quality, using Canon's Print Studio Pro plug-in.
- Canon imagePROGRAF PRO-2000 - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 101 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 12-ink - black, matte black, cyan, magenta, yellow, photo cyan, photo magenta, grey, photo grey, red, blue, chroma optimiser
- Max Media Size
- Roll A1 (61.0 cm)
- Min Media Size (Custom)
- 203.2 mm
- Max Media Size (Custom)
- 610 mm
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- RAM Installed (Max)
- 3 GB
- Hard Drive
- 320 GB
- Language Simulation
- PDF 1.7, SG Raster (Swift Graphic Raster)
- Media Type
- Plain paper, glossy photo paper, CAD tracing paper, CAD translucent matte film, coated paper, glossy paper
- Networking
- Print server
- Printer Features
- Borderless printing
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.7.5 - 10.11
- 111 cm x 98.4 cm x 116.8 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 18432 nozzles
- Minimum Ink Droplet Size
- 4 pl
- Ink Cartridge Configuration
- 12 individual ink tanks
- Ink Type
- Canon LUCIA PRO pigment ink
- Built-in Devices
- 3.5 inch LCD touch screen
- Connectivity Technology
- Wireless
- Interface
- 2400 x 1200 dpi
- Printer Features
RAM
- 3 GB
Storage
- Hard Drive
- 320 GB
Media Handling
- Media Type
- Max Media Size
- Roll A1 (61.0 cm)
- 203.2 mm
- 610 mm
- Media Sizes
- Roll A2 (42 cm), Roll (25.4 cm), Roll (40.6 cm), Roll (43.2 cm), Roll (20.3 cm), Roll (30 cm), Roll (32.9 cm), Roll (51.5 cm), Roll (35.6 cm), Roll A1 (59.4 cm), Roll (61 cm), Roll (25.7 cm), Roll A3 (29.7 cm)
- Max Printing Length
- 18 m
- Media Thickness Range
- 0.07 mm - 0.8 mm
- Networking
- Print server
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Included Accessories
- 3-inch spindle adapter kit
- Consumables Included
- 1 x ink tank (pigmented black) - 160 ml , 1 x ink tank (pigmented matte black) - 160 ml , 1 x ink tank (pigmented cyan) - 160 ml , 1 x ink tank (pigmented magenta) - 160 ml , 1 x ink tank (pigmented yellow) - 160 ml , 1 x ink tank (pigmented photo cyan) - 160 ml , 1 x ink tank (pigmented photo magenta) - 160 ml , 1 x ink tank (pigmented grey) - 160 ml , 1 x ink tank (pigmented photo grey) - 160 ml , 1 x ink tank (pigmented red) - 160 ml , 1 x ink tank (pigmented blue) - 160 ml , 1 x ink tank (pigmented chroma optimiser) - 160 ml , 1 x printhead , 1 x maintenance cartridge
- TUV, CB, RoHS, EAC
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 88 Watt
- Power Consumption Stand by
- 1.8 Watt
- Software Included
- Drivers & Utilities, PosterArtist Lite, Quick Utility Tool Box
- OS Required
Environmental Standards
- ENERGY STAR
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
- Sound Emission (Idle)
- 35 dBA
- Sound Emission (Operating)
- 48 dBA
- 111 cm
- 98.4 cm
- 116.8 cm
- 101 kg
- Width (Shipping)
- 132.4 cm
- Depth (Shipping)
- 90.2 cm
- Height (Shipping)
- 104.2 cm
- Weight (Shipping)
- 129 kg
