Cables Direct VGA Cable HD-15 (M) to HD-15 (M) 7m - Black
Quicklinx: CC1JWS00 Mfr#: CDEX-707K
Our range on Super VGA cables are constructed using 28awg triple mini coaxial cables, this allows them to be used for extended distances. Triple shielded with braid, foil and drain wire. Our cables are designed for standard monitors and widescreen LCD’s that require DDC cable.
Cables Direct VGA cable - 7 m
VGA cable
Triple shielded
Molded, drain wire
Length
7 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
DDC
1-year warranty
VGA cable
Triple shielded
Shielding Material
Foil with copper braid
American Wire Gauge (AWG)
28
Molded, drain wire
Length
7 m
Connector
DDC
1-year warranty
