Product
Cables Direct VGA Cable 2m
Quicklinx: BMMGWS00 Mfr#: EX-023
Length: 2m
More than 50 in stock
£3.27 ex VAT
£3.92 inc VAT
Our range of VGA cables are constructed using 28awg conductor cables, shielded with drain wire. Our cables are designed for standard monitors and may not work with widescreen LCD’s that require DDC cable.
Cables Direct VGA cable - 2 m
VGA cable
Shielded
Molded, thumbscrews, drain wire
Length
2 m
Connector
HD-15 without pin 9 - male
Connector (Second End)
Grey
1 year warranty
VGA cable
Shielded
Shielding Material
Aluminum mylar foil
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
2 m
Grey
Connector
15 pin HD D-Sub (HD-15) without pin 9 - male
1 year warranty
Length: 2m
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
