Brand
Cables Direct VGA/Audio Cable - 3m
Quicklinx: B3WTWS00 Mfr#: CDEX-603
Length: 3m
£4.72 ex VAT
£5.66 inc VAT
The SVGA cable with audio is the ideal solution to connecting audio to monitors that have built in speakers or work spaces with speakers in close proximity to the monitor. This cable can also be used for equipment that uses an SVGA + 3.5mm stereo cable.
Connect one VGA connector to your computer and a 3.5mm stereo, connect the other VGA connector and 3.5mm to your monitor with speakers.
  • SVGA male connectors
  • Nickel plated SVGA connector
  • Built in 3.5mm stereo
  • Copper SVGA cores
  • Black
Cables Direct VGA / audio cable - 3 m
VGA / audio cable
Length
3 m
Connectors
HD-15 (VGA) - male , Stereo mini jack - male
1-year warranty
VGA / audio cable
Plated Connector
Nickel
Length
3 m
Connectors
15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
1-year warranty
Length: 3m
Brand: Cables Direct
