These VGA cables are constructed using 28awg conductor cables, shielded with drain wire. The cables are designed for standard monitors and may not work with widescreen LCD’s that require DDC cable
- Cables Direct VGA cable - 5 m
- VGA cable
- Technology
- Shielded
- Molded, drain wire
- Length
- 5 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- 1-year warranty
- VGA cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 5 m
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 1-year warranty
