- Supports one PS/2 device, (keyboard) and converts it to the USB interface
- Easy to install, no software driver needed
- No power adaptor is needed
- Complies to USB 1.0 and 1.1 specification
- Only bus-power mode used
- Plug and Play
- Cables Direct keyboard adapter
- Keyboard adapter
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 6 pin mini-DIN (PS/2 style) - female
- Keyboard adapter
- Connector
- Plug and Play
